JVC Everio GZ-MG37 Camcorder
GXMG77 Everio camcorder - issue with data transfer...
posted by eric47898 on Jan 02, 2008
Everytime, even if I use the software to attempt move, I try to copy and/or move my files from the camcorder harddrive the connection is lost. It begins to transfer files, and indeed I have about 4 short clips that are available on my desktop. It almost appears as if the camcorder harddrive times out. I lose all folder structure to the camcorder harddrive in my explorer window and I have to disconnect/shut off and reconnect/turn on my camera, but it only lasts for about 3-5 minutes at best.
I am connecting to Windows XP w/Media Center and do have the external power cord plugged in so as to not attempt the transfer on battery power.
Any ideas?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 14, 2008
Not Rated (0)
g33kg1rl
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes even though it doesn't make sense, the only thing that was found when I brought mine in was that the Battery was corrupted. JVC even after having it in the shop and NUMEROUS calls to customer service. They could not reproduce this problem. Until they brought me to the back to the tech and realized the only thing different was that the battery pack was not in. For some reason the battery pack was corrupted and was causing this issue. I say if you have time on your warranty bring it back and buy a new camera.This will keep happening to the battery packs and JVC will want you to keep buying new batteries. As well as start charging 90 dollars an hour even in warranty to fix it. They kept trying to hold on to it longer and longer till the warranty just ran out.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on GXMG77 Everio camcorder - issue with data transfer to PC:
I don't want to Accept this solution
Can you Help with these Camcorders problems?
My camcorder dropped a short distance onto my sprung wood...
i performed all the possibilities as indicated in the...
I have a GZ-MG37U camcorder and a CU-VD10U burner. I can...
I was able to download approx. 2 hours of video to my...
When I try to burn a dvd with my new JVC Everio GZ-M360BU...
Loading problems.
Repair Service
Find Camcorder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
