Question about Hitachi 43FDX01B TV
Re: 43FDX01B blue convergence issues
Blue does not line up
  • 2 more comments
  • JohnTVman Jan 02, 2008
    blue convergence does not line up horizontally, replaced convergence ics-no change
    any assistance is greatly appreciated
  • 89racer Jan 09, 2008
    Yes I have the same with mine. The blue is diping down across the screen
  • Txsys Jan 26, 2008
    The green and red are out of convergence and I don't see the blue since it might be out or on the bottom. Where are the convergence boards located? Are they the ones attached to the CRTs? What's the P/N on the ICs? First time on this TV (my own) and don't have a schematic.
    Thanks.
  • Cary Farah
    Cary Farah May 11, 2010
    did you check the resisters off the converence ic's?
    Genius:
  • 1,694 Answers
Ditto CTF1800's comment....Check RP-41 1.5 ohm 2 watt and
other low value resistors near IC's mounted on large heatsinks.
STK392-110 original convergence IC's can be upgraded to
Hitachi # CZ 01341 new number STK394-160E for greater reliability.......Hitachi also has an IC / resistor kit # X480295,
but I don't change good resistors, only the bad one(s).
Practice good visual acuity technique and ask questions!.....T.
Posted on Jan 27, 2008
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
Blue vertical line on my desktop
The blue lines are a sign that the screen itself is failing. You can try to reseat the data cables from the motherboard to the back of the screen, but in most cases this is indicative of an immenent screen failure.
Jan 13, 2010 | ASUS G1SN-A1 Gaming Notebook PC
Blue lines on dell lap top inspiron
Check whether blue lines are present in bios screen, if Present then Hardware issue
If Blue line not present in bios screen, Software issue = Restore system back to factory settings
Connect External Monitor, use Fn + F8 to extend display on external Monitor ,
if display is fine on Ext Monitor = Replace LCD Kit
if Blue lines are displayed, on Ext Monitor = Replace Motherboard
Jan 09, 2010 | Dell Computers & Internet
How to install a water line to a Samsung Refrigerator?
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Jan 11, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung Monitor 2232BW
consult a technician you could not do any thing for this fault
Aug 23, 2008 | Samsung 226BW Monitor
Wires from the wall are 2(orange/white), 2(blue/white) 2(white/orange and 2(white/blue) my phone outlet which is wired has 1(black), 1(blue), 1(yellow) and 1(black. How are my wall wires to be attached...
Take a look at this image:
0d5b58e.jpg Notice that the Line 1 will typically present on pins 3&4 and Line 2 on 2&5. I would think in your case Black/Blue is Line 1 (3&4) and Yellow/Black is Line 2 (2&5).
If you have a 1 line phone and only have 1 line active, then typically blue and blue/white can be connected to the Blue and Black of your Jack. If this doesn't work, switch with the Yellow and Black.
Please let me know if you have further questions. Good Luck!
Aug 11, 2008 | Lands Phones
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Hitachi 43FDX01B TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
