Question about Harman Kardon AVR 25 MKII
Harmon kardon avr 25 ii
Someone posted this and I am having the same problem. Someone recomended getting some type of plug to block output, but when i ask anyone at radioshack or best buy they have no idea what i'm talking about. Can you help me?
i recently got this harmon kardon avr 25 II from a friend who said it worked perfectly, when i hooked it up to brand new speakers i got no sound, no matter the input. no tuner, no phono...nothing. when i put in headphones and turn the volume to it's max i can barely hear a whisper but that's all the sound i've ever gotten from it
I upgraded my HK AVR 20II and ran into the same problem when I tried to hook the old unit up out in my garage.
Luckily I remember that on the rear there is a pre-out RCA port (L/R) and a Main-In port that are intended to be to/from an equalizer/amplifier. These come jumpered out of the box, but I had been using an equalizer so the jumpers were long lost.
Assuming you also have no amp/eq you are using, just connect the Pre-Out to the Main-In using a standard M/M RCA cable and you will be in business. (turn the volume down first!)
Good luck.
Posted on Apr 25, 2009
First check to see if you have two jumpers on the back of your unit located near the upper left. They should be plugged into the main in and pre out for both the right and left channels. Those input outputs are for using external amps or receivers and should be bridged when they are not being used. If you are missing these plugs I think you may be able to use some very short RCA cables or call a shop specializing in high end stereo components for replacements.
Secondly, there will be two buttons on the front of your receiver under "speaker" One will be 1 the other will be 2. Now look on the back of your receiver to determine which channel you are using. If your speaker wire is coming out of Front 1 outputs then press in the button 1 on the front. If your speaker wire is coming out of front 2 outputs then push in button 2 on the front. Only one button should be pressed in is you are only using one set up speakers. If you are running two sets of speakers from the same front channel then press in both buttons.
If this does not fix your problem then next take off the top cover plate and check all your fuses for continuity with a multimeter. Be sure your receiver is unplugged first. There should be 4 fuses near the rear on the left hand side if looking at it from the front. The one closest to the front is the main fuse and if it is blown you will not get any power at all. Not even the amber standby power light will come on.
If none of this helps I don't know what to tell you anymore. A certified repair shop will charge between $125-$175 to fix most problems. You can buy a used working Harmon Kardon receiver for probably around the same price on Craigslist.
Posted on May 06, 2009
    An user who is expert in 3 categories / brands.
  • Harman Kardon Master
  • 924 Answers
Hello. My name is Dave. If you have no sound, first unplug the unit for a moment. Plug it back in. When you push the power button, you should hear one click. With about 5 seconds, you should hear another click. If you don't hear the second click, you have amplifier damage known as DC Offset.
Posted on Sep 30, 2012
You need to make sure that
1. THe pre-in and Out jumpers are in place.
2. The vcr seletions are off.
3. the right speaker buttons are in and out.
Happens on mine a lot... someone means to hit the power switch and hits the speaker select...
Posted on Jan 29, 2008
It is very passible that you have a cold solder joint on the circuit board somewhere, if so it could have broken loose durring shipping. Look for any device that has mass that could have broken loose due to inersia. typicaly a power coil with an iron core etc. Good luck...
Posted on Jan 06, 2008
3 Suggested Answers
SOURCE: harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Posted on Oct 30, 2007
SOURCE: no sound?
yeah actually the prein jumpers were the problem...they had worn of those "could have kicked myself" things....thanks for the help tho
Posted on Feb 21, 2008
I am stuck on the old oil rig, do not see where to go? I have only gotten 71 of the blocks.
if you are playing a game ask online players
there is nothing in your statement that refers to cars and trucks
Aug 25, 2017 | Cars & Trucks
What exactly is this site?
Maybe your questions were not about something our army of experts can answer. You can't pay enough to get someone to talk to you. Fixya does not work that way. You post a question, someone types a response.
Jul 02, 2014 | Nissan Maxima Cars & Trucks
I have someone who was a so called friend posting lies about myself and anyone she gets angry with. these are all lies and I could loose my job
you can block that person from posting stuff on your wall. or you can report it as spam/threat/irrelevant/harmful. the best would be to block her from your profile.
Aug 21, 2013 | Facebook Computers & Internet
Change spark plugs 2003 an recomend type plug
Don't use anything but AC Delco 41-103's TB's love these. You can get them at the dealer, but can get them cheaper from someone like Autozone. Our TB's don't like the normal replacements you find at autoparts stores.
Dec 08, 2010 | 2003 Chevrolet TrailBlazer
My RCA RS2620 has a shorted D820 and a burned R886. Can anyone recomend replacements / know the value of R 886 or have a schematic of this unit?
hi rnollett,
I just plugged my cousins RCA RS2620 into 220volt mains and burned the transformer because its originally 110 volt rating from canada. If you could please test your units transformer output voltages of RED-BLACK-RED wires so I can tell the technician to rewind the transformer usable to 220volt mains, he is asking me those output voltages and I dont have a clue.
Regarding your D820 and R886 if you have'nt yet found suitable replacements, in return, I will check the values of those parts here and I will send it to you.
Many thanks in advance.
Jun 11, 2010 | RCA RS2620 Single Cassette Deck
LCD Television
I live in Canada.
Personally I do not think many service techs do this type of component level repair.I would suggest to ask around and see if someone can fix it.
If you decide to send the power supply for repair, let me know.
Nov 12, 2008 | Astar LTV-3201 32 in. LCD Television
Yamaha RX V490 Turning itself Off
The amp is in protect mode which means that the output section has a problem. With nothing connected, there are defective parts inside the unit. This type of problem is not likely to have been caused by any shipping damage. I would guess that the output transistors are shorted.
Jul 22, 2008 | Yamaha RX-V490 Receiver
2,319 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
