header usb usb67 on asrock p4i65gv motherboard not working
Comments:
Nov 01, 2009
- When i connect a usb drive in front panel USB slot then a message is fashed in icontray that 'One of the usb device attached to this computer has malfunctioned, and widows does not recognize it.'
The one next to the Floppy Disk Drive header? Yes, I see it. (I'm looking at the Motherboard Manual in PDF file format, from AsRock Support)
Since the USB67 header is used to add additional USB 2.0 version ports, it's usually used for the Front Panel.
If someone connects the wires wrong, it can burn this header out. Someone before you may have done this. It could also be that it is of poor design, and eventually just failed. Happens.
I would suggest buying a USB 2.0 version adapter card, and installing it in an unused PCI slot.
Sir, I have a Intel 945GCM-S+ICH7 Chipsets Motherboard. I am facing a problem since from last 4...
(More)
Sir, I have a Intel 945GCM-S+ICH7 Chipsets Motherboard. I am facing a problem since from last 4 months that whenever I insert any data storage device(like Pen Drive, iPod etc), my windows suddenly crashes. I am using Windows XP SP3. I have tried many solutions but my problem still persist. I have reinstalled the windows, and many more things I have performed but nothing happens. I think its the problem with motherboard. What should I do for this? Please Help me :(
i have a desktop dv9000, that have stopped connecting the monitor, i tried the monitor on my other...
(More)
i have a desktop dv9000, that have stopped connecting the monitor, i tried the monitor on my other desktop and it works,what could be the problems
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the...
(More)
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the maf sensor and which wires to connect to. There is also a wire for the o2 sensor? Regards Terry
set up my routter and still having a low id where it doesn't even get close to the speed it used to...
(More)
set up my routter and still having a low id where it doesn't even get close to the speed it used to get only downloading at max 20kbs which it used to get it up to 200kbs what could be the problem i am using d-link dgl-4100
