Power options for monitor
Hi, the power options for my monitor (NEC AccuSync90) keep going back to shut off after 20 min., i've changed the power setting to never shut off, but after a couple of hours it changes back to off in 20 min., i've used this monitor with other towers and have had no problems of settings reverting back . i'm running xp pro sp2, all updates have been done. and my tower is AMD athlon 64X2 dual core processor 4200+ , 2.20ghz, 1.87GB of ram . so do i need to modify some registry keys or something so that my monitor always stays on ? thank you for your time.
  • 180 Answers
SOURCE: with dvi monitor goes black for 2 second then comes back intermittently
To what I understand. Dvi and vga is only applicable to a system or CPU. Sorry if I am wrong.
Posted on Apr 17, 2008
  • 33 Answers
SOURCE: Lacie Silverscreen 80Gb Drive not recognised by My Dual Processor PC
Sorry for the late reply, but it may help someone else with the same problem.
Are you using a USB2 port, perhaps it's may not be getting enough power. In the orginal Lacie box was a double USB dongle - it allows you to take the power from two USB ports and send them to the Silverscreen, if the SScreen was getting quite enough power.
Or buy a double USB power cable (like:
Otherwise remove the 2.5" disk (remove two screws, & gently pull out) and use a caddy to check the HD disk is still working.
Posted on Sep 12, 2008
  • 55 Answers
SOURCE: acer monitor, AL2016W, LCD, display will not stay centered.
hello sorry i don't know the answer but i did not think that this problem is related to failure of cmos battery or the failure of memory ic in monitor.
if any one give any suggestion plz send me the solution also
Posted on Nov 13, 2008
SOURCE: change settings and hold them on vw 192 T asus monitor
can pl i get asus vw192t monitor drivers
Posted on Feb 17, 2009
  • 4 Answers
SOURCE: LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
Posted on May 12, 2009
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
What is the fix to a TV - AccuSync PV46 that gets hot and turns off within about 5 or 10 mins.
open your monitor in on condition and see which component geting hot ok change component with new one and check it aain
May 19, 2012 | NEC AccuSync Computers & Internet
How do I set the NEC LCD194WXM monitor to shut down after 5 mins, 10 mins, 1 hr., etc., etc. Mine stays on all the time!
To change this, do the following:
1) Navigate to the Control Panel by clicking Start and then Control Panel. Then double click on Power Options as shown below circled in red.
2) This will then display the Power Options window as shown below.
3) Once you have opened the Power Option Properties, under Power Schemes select the one that best suits your PC system.
4) Then you can select whether or not to switch off your monitor and/or hard drives after a period of time when it is not being used.
Apr 15, 2011 | NEC MultiSync 1940CX 19" LCD Monitor
My computer monitor keeps shutting off randomly for no reason. It isn't the sleep function I've already checked that and it happens when you are in the middle of using the system. I am running xp
Click Start, click Control Panel, click Performance and Maintenance, and then click Power Options.
Now you will see Power option Properties.
Now see the Settings for normal power scheme.
Under this Make sure that the options like Turn off monitor should be set on never and not on After 5 mins or 15 mins
After changing the settings hit on the apply button and then click on ok.
Check this link and you will be able to unuderstand more...!
still you have problems let me know..!
May 10, 2010 | Computers & Internet
Gateway FHD2400 24inch monitor HELP PLEASE!
well it's not the computer going to sleep but the monitor is (sort of) because your computer is telling to. it has to do with the Power Options (title dependent on OS - this is what it's called in Vista)
Go to Control Panel>>Power Options - on the left hand column click Choose when to turn off the display - I'm guessing you are set to 15 or 20 minutes for the Turn off the display dropdown - change it to something longer to satisfy your needs (Never is an option).
If you're not running Vista write back - it's slightly different but similar path.
Mar 31, 2009 | Gateway FPD2275W LCD Monitor
Laptop keeps shutting down
Check the key hybernation
Start >> Control Panel >> Power Options >> Hybernate (must be UNCHECKED)
See another features.
Check your bios at CPU to check if overheating feature is activated,
check the temperature of your CPU
Oct 29, 2008 | NEC Versa Premium Notebook
Monitor shuts off during use
3 years old and generally rated as a Mediocre monitor to begin with, I'd say I'd invest in a new monitor
Here are some replacement options:
Sep 10, 2008 | BenQ FP72G+ 17" LCD Monitor
try by uninstalling the video driver from safe mode and reinstall the driver.if the problem persist then your monitor needs servicing
Apr 02, 2008 | Gateway FPD2275W LCD Monitor
Dell 1704 FPTt monitor goes black after about 20 min
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Dec 22, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
LCD Monitor power problems
yes the monitor is over heating there should be warranty on the montor
Dec 15, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
Open Questions:
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
