do it only if u r a professional.. assuming that the system bios hs not been flashed or updated in a wrong way..if so u gotta replace the m/b.. 1st see if the ram(s) is loose/faulty..open n resit it.. check for ac main supply and fuse..next check all the outputs of smps
viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg
& grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try
repairing or replacing the power supply with a standby n see.. if all above are ok..check the cmos/system battery..(above +3v).. check the cpu fan rotating and the cpu generating heat..try replacing the cpu with a standby (if no heat is generated).. there may b a chance for m/b's crystal clock generator to b faulty..try repairing or replacing the m/b with a standby.. hope it'll b enough to solve ur problem.. seek professional assistance of ur system admin/vendor....
Was this helpful?
Yes
No
7 people thought this was helpful
Popular Solutions for HP Compaq Presario F500 F700
It had an intermittant black screen. Than the wireless lan wouldn't connect. The wireless lan...
(More)
It had an intermittant black screen. Than the wireless lan wouldn't connect. The wireless lan problem fixed itself. Two months later it won't start. Blackscreen w/power button lit.
Compaq presario f600 internet not working. It's wi-fi doesn't work and it doesn't work even when...
(More)
Compaq presario f600 internet not working. It's wi-fi doesn't work and it doesn't work even when plugging it in straight to the cable.
