Intel Pentium 4, 2 GHz Processor
No display
posted by joebilge on Jan 02, 2008
I've just changed my motherboard and cpu to a ASRock P4VX4 with Pentium 4. Once turned on there is no display on the monitor. Is this likely to be caused by the processor being faulty ( I bought it on ebay from someone who said they thinks it works ok)?
When I changed back to my original board it works fine. Since the only difference between the two is the boardand the processor it leads me to think the processor is faulty.
Comment posted on Jan 02, 2008
It doesn't make any noises, and as there is no display I can't tell if its actually doing anything. The video card works fine on my other board. If its the built in video controller is the whole board pretty useless?
Yes the fans are all running, the hd led goes on for a while. Everything on the board looks fine. The card in the AGP slot works fine in my other board, should I maybe try a PCI? Can I rule out the processor, thats what I was most suspicious of as the guy selling it didn't seem 100% sure.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
tom19511
Rank:Guru Guru
Rating: 85%, 1800 votes
If it boots with no video, then it is a bad built-in video controller. If you get a long beep then its the processor.
No, you can get either PCI or AGP video card adapter if it supports it.
You say that you don't hear anything. Can you see if the fans are running?
Check the capacitors for bulges and leaks. Thats a sure way to tell if the board is bad.
Go into the Bios and set everything to default. Then see if the video works without your card if has a builtin video card.
Comment posted on Jan 04, 2008
yes, you can rule out the processor.Please keep me informed.
thanks,
Rating Locked! (?) joebilge has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No display:
I don't want to Accept this solution
Can you Help with these Processors problems?
Processors
Help me please can not download the Adobe reader 9 keeps...
Processors
i just hooked it up and it keeps flashing out of range
Processors
Yahoo mail says i have a message,before i open it!! But,...
Processors
The mouse is locked and i cant go anywhere it is very...
Processors
im gonna buy a dell xps 1530 with 64 bit vista os. will...
Loading problems.
Repair Service
Find Processor Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
