vizio vl320m. I set it up wrong. Instead of choosing a different source such as my cable box during the initial setup I chose cable. Now i cannot get any channels in digital quality and I dont know how to restart the tv. I am unhappy because this is a new tv and I was really exited to get it. How can I change the input source? Please help!
Comments:
Oct 31, 2009
- Yeah. I found an option to restart the system in the menu. I do exactly as the manual says: if you have a cable box, push "last" on the remote instead of choosing cable or antenna. I do this and nothing different happens except it skips the channel search. I tried searching again and all of the channels still only come in in analog, not digital. I have cox communications and I know they have digital programming. Any ideas?
You should be able to use the input/source function on your remote to select which signal sources you want the TV to display, find out which input on the TV you have the cable box hook it up to then just select that input. Do you still have the user manual?
I have a 2 year-old 52" Mitsubishi LCD TV. I turned it on today and saw a double line on the...
(More)
I have a 2 year-old 52" Mitsubishi LCD TV. I turned it on today and saw a double line on the left side about 6" in. It is one black line with a yellow shadow line. Is there anything I can do to fix it or do I need to take it in? Thank you.
Our Panasonic Viera turns itself off, then flashes red 4 times, then 4 second gap and repeats, we...
(More)
Our Panasonic Viera turns itself off, then flashes red 4 times, then 4 second gap and repeats, we can turn it off then back on again but only lasts about 10 mins before it does it again. Some days it lasts all day without happening, others it just turns off continuously.
I cant change the audio on my vizio. It is stuck on "flat" and says that the setting cant...
(More)
I cant change the audio on my vizio. It is stuck on "flat" and says that the setting cant be changed. The sound isnt great with that setting on. I tried reseting the audio settings to see if it would let me change it, but i would not. It also says the equalizer cannot be changed. I would like these settings.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
