Visioneer 4400 Flatbed Scanner
Problem for Visioneer 4400 Flatbed Scanner
Is there a way to install Visioneer 4400 on Windows 7?
By jimyue on Oct 31, 2009
I upgraded from Vista ultimate to Windows 7 Ultimate and now my visioneer 4400 cannot be detected. I uninstalled the driver and tried to reinstall it using compatibility mode Windows XP sp2 and Windows 2000 but both attempt failed. The installer wizard installs the driver files and then ask to click the "Finish" button after my computer detects the scanner. The problem is that my computer is not detecting the scanner to finish the install.
Comments:
Nov 04, 2009
- I finally got it to install. This is what I did: since I have tried to installed the driver executable file 4400.exe that I had so many times under different compatibility modes, I went through remove/add programs and uninstall the driver files. Rebooted my computer to make sure nothing is left in memory. Plug in the usb cable from scanner to computer and rebooted. Went to device manager and clicked on "Scan for Hardware changes" button. The "Imaging Devices" folder appeared in the list and my computer recognized the scanner as "42 Bit USB Scanner". Right click on "42 Bit USB Scanner" and select to update driver. You will be prompted to either Search for driver automatically or manually browse my computer. Choose to search automatically. Microsoft will find a working driver version and voila! my scanner worked. The driver version that is installed says: Visioneer version 3.0.0.0 dated 8/28/2001 (when clicking on the Driver Details button, it says: File version 6.1.7600.16385(win7_rtm.090713-1255).
Nov 05, 2009
Solution #1
posted on Oct 31, 2009
Not Rated)
drifterK
Rank: Guru  Computer Hardware  Expert
Rating: 86%, 359 votes
Im not sure that will work with the driver for xp ...try again with the vista driver ..cause this are the ones most closed to windows 7...and get started from the device manager ...so in this way the scaner will be first seen and than add the driver by updating it ...
Comments:
Nov 05, 2009
- yep ..this is the way to do it ...
Was this helpful?
Yes
No
Solution #2
Not Rated)
nanbuenbrazo
Rank: Wiz  Computer Hardware  Expert
Rating: 78%, 167 votes
there are still no driver that can support the windows 7 for Visioneer 4400. No luck for that as of this time
Was this helpful?
Yes
No
Popular Solutions for Visioneer 4400 Flatbed Scanner
Questions and Unsolved Problems for Visioneer 4400 Flatbed Scanner
Do you recommend Visioneer 4400 Flatbed Scanner?
Answer
Answer
I have the disk and have bought a new computer with Windows Vista. Apparently my Scanmaker 4900 does... (More)
Answer
I need help figuring why the sliding rear window on my 2005 F-150 will not open. I used it last... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Visioneer 4400 Flatbed Scanner:
Top Scanner Experts
Rank: Guru Guru
Solutions: 764
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
