Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony KV-32hs510 Colors fouled up
I see mostly red and blue. Peoples faces look like infared images. Only an ocassional green object. I have been unable to locate a service tech in my viscinity. I guess the price of tv's are such that there is no profit in service centers. Anyway, I would like to try to fix it before I throw it out. Any advice would be appreciated.
  • Anonymous Jun 15, 2008
    Sounds very similar to what just happened to my KV-32HS510.
It seems you have degaussing problem.
Posted on Oct 26, 2008
Same thing happend to me. KV-32HS420. first happened while my laptop was plugged in through SVideo port a month ago. hopefully the laptop did not cause it.
problem has progressively gotten worse (no laptop since). basically the picture turns reb/blue only for extended periods. dips back into normal picture, then back to red/blue.
Posted on Aug 24, 2008
  • futch258 Dec 30, 2008
    de-gaussing? i know how to do that with a computer monitor (menu option) but how can i do it with the Sony TV?
  • futch258 Jan 03, 2009
    i took a closer look and i'd say there is no white. any ideas? here is a photo;
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Blue colors are now green.
It sounds connections are not matched yet. Make sure connections are green to green, red to red and blue to blue in dvd player and tv are correct.
Try another component video cable.
If problem still exist, test dvd player to any other tv, found ok then component input of this TV is bad, need to get it repaired.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kv-36fv27 color is bad.
Know to solders?Resolder ur video board socket holes that connected to( CRT tv Tube).Resolders the Yoke cable red, green,yellow connected to the main board also.Should get colors back,if the colors IC on the video in not dead,and capacitors help the IC on the video board.
Dec 19, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Problem with 1999 Sony Trinitron Wega 32 inch TV
sounds like the tube has gone any good tv repair shop will be able to replace it cheapley.
Mar 08, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Kv-32hs510 6 blinks
This just happened to me. I was all set to send it out but there's a snowstorm right now. Thank goodness I checked another thread on Hold the setup button on the original remote while pushing the ON/OFF button on the TV at the same time. This worked for me. Here's the link I got this from: Good luck!
Nov 04, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Screen went dark
Sounds like the screen control which is usually mounted in your high voltage transformer (Flyback) has opened up. Stargazer
Jan 10, 2007 | Sony KV-27S20 27" TV
32 inch sony trintron tv red blue green
Switch OFF TV. Open rear Cover. Switch ON the TV. Now, very carefully, (There are very High and Dangerous voltages inside, also, use a mirror to see the screen) adjust a red colored box called "H.STAT" which controls the Horizontal Convergence of the CPT. Should solve your problem. Check some Vertical portion of a object (Text in some Video Title, wall of a building, etc, ) as a reference.
Sep 04, 2006 | Sony FD Trinitron KV-28FQ75 28" TV
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
