NetGear WGT624 Wireless Router
Problem for NetGear WGT624 Wireless Router
I'm having a problem with my NETGEAR WGT624v3
By spearman986 on Oct 31, 2009
I'm having a problem with my NETGEAR WGT624v3 router. I have it connected through a SPEEDSTREAM 4200 modem and have experienced no problem with the internet connection. However, after approx. 3 to 4 hours of wireless use, the wireless signal drops then reconnects for between 5-15 minutes before continuously dropping and reconnecting, forcing me to disconnect the router for about an hour. Repeat process. I've updated the firmware and its still occurs. Any ideas? Thanks.
Comments:
Nov 01, 2009
- I was unable to access my modem at all. Could you describe the process in detail so that I can check potential mistakes I made?
Solution #1
posted on Oct 31, 2009
Somewhat Helpful)
PhoneDude
Rank: Wiz
Rating: 85%, 70 votes
yes set the speedstream modem to log in. it is uner advanced, usually 192.168.0.1 address. It is most likely set to "bridged" mode and using the router to login. set login to ppoe on speedstream on one p.c. only 1st. with login ang password filled in and "smart keep alive" on.
Was this helpful?
Yes
No
Solution #2
posted on Nov 03, 2009
Not Rated)
chinmay_pat
Rank: Guru
Rating: 89%, 23 votes
Is it the connection between the laptop/desktop and the router or it is the connection between the router and the modem that drops frequently?
If it is the connection between the laptop and the router that is dropping too often, then there is something you can do in your network setting for wireless network.
In a public network (which is usually unsecure) the connection drops frequently.
If you or only a few persons are the only user(s) of your router and your WLAN is securely encrypted, then try changing the wireless settings of your laptop to be in "private" network, which will solve your problem. The issue occurs when the type is "public".
Was this helpful?
Yes
No
Popular Solutions for NetGear WGT624 Wireless Router
Questions and Unsolved Problems for NetGear WGT624 Wireless Router
Do you recommend NetGear WGT624 Wireless Router?
Answer
Answer
i have forgoten my password on my virgin router
Answer
i am having hp pavillion dv6 i couldnt able to connect with my netgear WGT624v4
Answer
I get a "failure" message trying to add Netmeeting to portforwarding
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
