Question about Sony Playstation 3 (PS3) Console
Does not come on
I posted in solution,but i have a question not an answer,is there a fuse for the ps3,my sons ps3 does not come on,i checked to make sure the power switch is on. i dont know what caused it not come.just asking if there is one.
Try the fuse box in your house first then check if your plug is working (on the wall). If its broken you'll have to send it to Sony.
Posted on Jan 02, 2008
6ya staff
SOURCE:
My sons ps3 screen is black after trying to hook an old off brand web cam is there a fix for this?
You will have to disconnect the web cam first. Then follow some simple steps to reset the video output on the PS3. I will post a link to a youtube video that will guide you thru the steps.
HOW TO RESET HDMI Video PS3
May 03, 2014 | Sony PlayStation Video Game Consoles &...
My son tried to connect his ps3 to the tv via the hdmi lead the sound comes on but no picture can you help please
okay you have to reset your ps3 tell your son to turn ps3 off then hit power button hold your finger on it till it shuts off then hit it again till it beeps twice make sure your tv is on and you HDMI is hooked uo properly it usually beeps twice about 5 to ten s4econds after you hold it a second time for the 2 beeps you have to be quick at this
Mar 20, 2013 | Video Game Consoles & Games
My son was playing his PS3 for an hour or so. I went and turned it off for him when he decided to leave the room. I pushed the ON/OFF button (on the left side of the TV) and realized I had the remote...
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jun 15, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
No power red or greenlight
On the back of the console look at the power cord make sure it's fully in and it might look like it is sometimes but give it a push to be sure and check the power outlet on the wall
Apr 06, 2010 | Sony Playstation 3 (PS3) Console
My son plugged the wrong power cord into Sony Playstation. now when he plugs the right cord in nothing happens. Is there a fuse or something that can be replaced?
is it the power cord i assume ? make sure the little flip power switch above the power cord is in on position. and u should have steady red light on front of ps3 when unit has power on. using a different power cord should not affect it but its not recommended . most ps3 uses a standard power cable.
Mar 06, 2010 | Nintendo Wii Console
I connected my sons ps3 to our new hd tv and now it wont connect to his tv as it only seems to be using the hdmi output which his tv does not support
Turn the PS3 off and make sure it is just showing a red light,
Then, with the PS3 connected to the TV with the regular (not HDMI) connections, press and hold the power button.
As soon as you see the screen flicker, release the power button.
That should do it!
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
I was turning off my ps3 system by the main power every time and now it's not working
Same thing happened this weekend to my son. The system files became corrupt.
[email protected] has the answer in this forum and has a video explaining exactly what to do. This worked for me!!
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
No power to PS3
If you get no led lights, red lights or anything then it's likely that you need to replace the power supply. It's easy enough for the home user to do. If it's under warranty still then by all means use it. Otherwise open up the PS3 (you'll need a special T10 Security driver) I think you can get one from Radioshack but I'm not 100% sure. All the other screws are normal phillps. Then you'll see your power supply, it's the big square box on the left. Check to see which one you have and then match it up with a replacement one on ebay. They go for around $50 if I'm not mistaken. Make sure you get the same one you had before, they're not all the same.
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 Nothing..No Power Light.. Nothing
Hi there, by the sounds of it you could have faulty fuses, Whether its inside the console itself or inside the Power adaptor its Uncertain. Before opening up Your PS3 i would suggest Checking the fuse in the power adaptor to make sure that is not fried. if it isnt. then it must be something to do with the power input to your PS3 Device. it could be either the Fuse or The transistors on the Power input Circuit. When you Pop open your PS3, Go straight to the back-end where the power input is located, and see if any of the fuses or transistors look fried, if they are. then that is where your fault lies !
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
No power on PS3
I THINK YOU NEED TO BUY NEW RCA JACKS,, BECAUSE IF THE ELECTRICAL FUSE WENT FROMT HE TV TO RCA JACKS THEN ALL THE CORDS THAT PLUGS TO THE PS2 ARE SHORTED OUT.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
37 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
