Question about Toshiba Satellite Pro 4600 Notebook
How can I get the case open?
I have removed 5 screws inside the battery compartment (B6) plus one B6 under the laptop. 2 at the rear of the screen and 5 screws labelled B16 underneath. Something is still holding it all together. Do you know of a manual?
  • JRAustin Jan 04, 2008
    Thanks very much - I just couldn't find the manual.
    Sergeant:
  • 324 Answers
And a good day to you!
Follow this link:
http://www.claimexam.com/
Click on the gold colored "For the index..."
Open the Toshiba link (not the upper one, use the lower one)
Click on the 4600 link.
TaDa! You have the manual!
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Jan 03, 2008
How do i disassemble hp 635?
Don't know what manual you're referring to, but it isn't the HP 630, HP 631, HP 635, and HP 636 Service Manual; from HP Support,
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02834036/c02834036.pdf
Upper part of the laptop is the Top Cover.
Most of the time referred to as the Palm Rest Cover.
1) Remove the Keyboard
2) Remove the Optical Drive (DVD drive) (IF an option on your laptop)
3) Remove the Power Button Board and cable.
4) Remove the TouchPad Button Board and cable.
5) Remove the Top Cover
A) Close the computer
B) Turn the computer upside down, FRONT towards you.
Now pull this example of the Base Enclosure up in another window,
http://www.ebay.com/itm/646838-001-HP-635-BASE-ENCLOSURE-WITH-HDMI-/130659842589?pt=LH_DefaultDomain_0&hash=item1e6beefa1d
Put your mouse cursor in the middle of the photo, and use the Zoom In feature. (Put mouse cursor in middle, slowly move mouse around)
1) Looking at the FRONT edge, see the SIX screws that need to be removed?
2) See the ONE screw on the Left side, and Right side; that needs to be removed?
3) ONE screw to remove from EACH corner on the REAR side.
4) Battery Compartment / Rear side;
There are FOUR screws to remove that are along the Rear side of the Battery Compartment, and DOWN in the Battery Compartment.
4) Battery Compartment / Front side;
There are THREE screws to remove that are along the Front side of the Battery Compartment, and DOWN in the Battery Compartment.
5) DOWN in the Harddrive Bay Compartment there are FOUR screws to remove.
TWO on the Right side, TWO on the Left side.
IF I count correctly there are 21 screws to remove from the Bottom.
(I ran out of toes and fingers)
6) Turn the computer back over to it's normal position.
Open the laptop.
Grab the Jaws of Life and....................
Just wanted to see if you were following along.............
The rectangular area under where the Keyboard was, and has multi ventilation holes in it, is the Static Shield.
To the Upper Left corner is the Power Button Board cable, that needs to be disconnected.
To the Middle/Front is the TouchPad Button Board cable that needs to be disconnected.
Looking to the upper right there is a hole, and a screw that needs to be removed.
More detail;
Looking at the ventilation holes going across as rows.
Come down to the 3rd and 4th row of ventilation holes.
Come OVER from the Right side SIX ventilation holes.
That hole, that screw; needs to be removed.
IF it still uses this style of fastening;
The Top Cover has TABS going around the exterior perimeter, of the inside edges.
These Tabs snap into matching LATCHES in the Base Enclosure.
(Bottom Cover)
I use a thick stiff guitar pick to start popping the covers loose from each other. (Top Cover from Base Enclosure)
I would ease the pick in the parting line of Top Cover, to Base Enclosure, towards the Rear/Right side.
You just want to ease the pick in, so you can start to get your fingertips in.
Can't get the pick in? Move over. You are at a Tab/Latch.
Once you get the Top Cover to start to separate, use your fingertips, and move along towards the Front.
Go around the Front popping the Tabs/Latches loose.
By the time you get halfway around the Left side, the Top Cover may pop off.
I state MAY, because I have had some I had to fight all the way.
(Pop EVERY Tab/Latch loose)
I hope you are wearing an ESD wrist strap, and have it's alligator clip attached to a good ground source.
IF not, open the backdoor, and throw your laptop out.
(Unless you just want to use it as a doorstop)
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
An ESD wrist strap, and connected to a good ground source, will keep your laptop safe from Static. (From you)
The CPU (Processor) is the most susceptible hardware component to Static shock.
You know the above? Good. I also posted for people who read this solution in the future.
Out of curiosity what CPU are you going to install?
[Plus; DO NOT post your email address on FixYa!]
For additional questions please post in a Comment.
Regards,
joecoolvette
[Memory Module/Wireless Module Compartment Panel is removed, then there is a screw to remove down in the compartment, that is for the DVD drive.
Remove screw to slide DVD drive out of laptop.
Can't get a hold of DVD drive? Tap the tray release button, ease the tray all the way out. Gently pull on tray until DVD drive comes out enough, that you can grab it ]
Feb 25, 2013 | HEWLETT-PACKARD HP Compaq 635 156 Notebook...
How do i open dv7-1451nr?
Instructions
Shut the Pavilion dv7 down and close the screen. After unplugging all cables from the computer, turn it over and remove the battery.
Unscrew the six Phillips-head screws holding the large T-shaped panel to the bottom of the Pavilion dv7. Remove the panel and set it aside.
Remove the keyboard locking screw--marked by a keyboard-shaped icon--from the top part of the compartment exposed when you removed the T-shaped panel. Reserve the screw.
Remove the black Phillips-head screw from next to the wireless adapter inside the T-shaped compartment. This screw holds the Pavilion dv7 optical drive in place.
5
Pull the Pavilion dv7 optical drive gently out of its bay, and then remove the two Phillips-head screws from inside the empty drive bay. Reserve the screws.
6
Remove the Phillips-head screw next to the circular intake fan vent in the corner of the Pavilion dv7.
7
Remove the five Phillips-head screws from inside the empty battery compartment. You should now have removed 16 screws in all. Turn the Pavilion dv7 over and open the screen.
8
Insert a spudger or other flat plastic tool into the seam between the speaker grille and computer casing on the right side of the Pavilion dv7. Gently pry up to begin removing the speaker grille from the computer. As you do this, move the spudger to a new location to pry different areas until the grille is completely disconnected. Mind the ribbon cable connecting the center of the speaker grille to the logic board, and do not lift the grille any higher from the computer than the cable allows.
9
Push both sides of the speaker grille cable lock forward until the cable slides easily out of the logic board connector. Set the speaker grille aside.
10
Remove the four Phillips-head retaining screws above the top row of the Pavilion dv7 keyboard. Lift the keyboard up and forward, and place it face-down on the palm rest.
11
Unlock the Pavilion dv7 keyboard cable connector using the same method as for the speaker grille connector. Slide the cable out of the connector, remove the keyboard and set it aside.
12
Place the new Pavilion dv7 keyboard upside-down on the palm rest. Slide the keyboard into the connector, close the lock and rotate the keyboard down into the computer. Replace the four Phillips-head screws.
13
Slide the speaker grille cable into the connector and close the cable lock. Push the speaker grille into its original position above the Pavilion dv7 keyboard. Press gently on all parts of the speaker grille until it is flush with the computer casing.
14
Close the screen and turn the computer over. Replace the five screws inside the battery compartment, the screw next to the intake fan vent, the two screws inside the empty optical drive bay and the screw inside the T-shaped compartment.
15
Replace the t-shaped panel on the bottom of the Pavilion dv7 and its six screws.
16
Slide the optical drive back into its bay and replace the securing screw.
Jan 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
How to clean the fan in my laptop
As with any hardware on your laptop, the fan may stop working. Your laptop's fan serves as the dedicated cooling system for the CPU. If your CPU overheats it will cause severe damage to the motherboard. It may also cause electrical damage hardware devices nearby the CPU. Most HP laptops are designed with CPU fan located on the top side of the motherboard. There are a few HP laptops with the CPU fan located on the bottom side of the motherboard.
Shut down your laptop, and fold down the LCD screen. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Disconnect the AC power cable and any external devices. Place the laptop face down, and rotate the computer so the front opening is facing forward. Locate the battery pack in the upper right or left corner of the laptop. The location depends on your laptop model. Press on the battery's release button, and then lift the battery out of its compartment. Place the laptop face up and open the LCD screen all the way. Insert a flat-head screwdriver into the right side of the keyboard cover. The keyboard cover is a thin strip of plastic situated between the keyboard and LCD. Gently pry the cover from the laptop, and set it aside. Remove the Phillips-head screws located above the top row of keyboard keys. These screws secure the keyboard in place. Grasp the top edge of the keyboard, and then place the keyboard face down over the palm rest area. Disconnect the keyboard's large ribbon cable from the motherboard. Remove the keyboard from the laptop. Locate the small circuit board near the top of the laptop's upper casing above the keyboard compartment. Disconnect the cables from the circuit board. Remove the Phillips-head screws securing the circuit board in place. Close the LCD screen. Place the laptop vertically. Position the laptop with the back of the LCD hinges facing upward. Remove the single Phillips-head screw from the back of each LCD hinge. Place the laptop face up, and open the LCD screen until it is in the 180-degree position. Locate the LCD video cable extending from the left side of the LCD panel. Disconnect the cable from the motherboard. Remove the Phillips-head screws from each LCD hinge. Lift the LCD screen panel off of the laptop. Set it aside. Locate the CD/DVD drive inside the right section of the laptop's upper casing. Remove the Phillips-head screws securing the drive in place. Grasp the face of the drive and slide it out of its compartment. Place the laptop face down. Remove all remaining Phillips-head screws from the bottom casing of the laptop. This includes any screws inside the battery compartment, and on the back panel of the laptop. Flip the laptop over, and remove the remaining Phillips-head screws from the laptop's top casing. Locate the touchpad cable situated just above the touchpad area. Disconnect the cable from the motherboard. Remove the top casing from the laptop's base. Locate the CPU fan in the upper left corner of the motherboard. Remove the Phillips-head screws securing the fan to the motherboard. Disconnect the fan's power cable from its connector on the motherboard. Lift the cooling fan out of the laptop and set it aside. http://www.youtube.com/watch?v=qcy0YSOmX4E How to Clean the Fans on HP DV4 - Overheating This might not be you laptop but it might give you some insight. Hope this helps.
Jan 09, 2013 | Computers & Internet
Canon a1100is camera battery door replacement
Kurt- I have successfully completed a d-i-y battery door replacement on my Canon A1100IS, and I make no claims about being an "expert." My training was watching u-tube videos of guys disassembling digital cameras (other models). Here's how to open the case on the A1100is, which is not really much different than opening the case on most any compact digital camera.
Using a size #0000 phillips screwdriver (Sears sells a set of 6 minis--slotted and phillips--for $10), I removed the nine screws from the side and bottom of the case plus one inside the mini-usb cover and the one inside the battery compartment.
Then, I gently worked the front and rear of the case apart (the top of the case halves have two snap clips that hold them together. Unlike some cameras, the A1100IS does not have any flexible cable straps between its front and rear covers.
With the case halves removed, I then used a tweezers to move the straight end of the hinge spring out of its original place next to the tripod socket. That released spring pressure on the hinge and I could then easily remove the hinge pin with the tweezers.
Then, it's simply a matter of placing the replacement door's hinge/spring combo in the proper location and inserting the hinge pin to hold it there. I purchased a new door from Canon for $8.42 plus shipping). Then, I used the tweezers to position the straight hinge spring end in the slot next to the tripod socket.
The only thing left was to wipe my fingerprints off of the LCD screen and then gently replace the front and rear case halves--snapping the case's top together and then replacing the nine screws.
Feb 26, 2012 | Canon PowerShot A1100IS 12.1 MP Digital...
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
Jun 12, 2011 | Aston Martin Vanquish Cars & Trucks
How do i fix the heater core on my ford taurus 1995
Remove heater/evaporator case. Remove vacuum source line from heater core tube seal. Remove seal from heater core tubes.
Remove heater core access cover screws. Remove access cover and seal from heater/evaporator case. Lift heater core and case seals out of heater/evaporator case.
Installation
If installing new heater core, transfer case seals to new core. Install heater core and seals into heater/evaporator case. Install heater core access cover on case. Install seal on heater core tubes. To complete installation, reverse removal procedure. Evacuate and charge A/C system. Refill cooling system.
HEATER/EVAPORATOR CASE
Removal
  • Disconnect negative battery cable. Drain coolant from radiator. Gently pull instrument panel away from right side of dash panel.
  • Discharge A/C system using approved refrigerant recovery/recycling equipment. Disconnect heater hoses from heater core. Plug heater core tubes or drain coolant by blowing coolant from heater core using low pressure compressed air. Disconnect vacuum supply hose from inside engine compartment.
  • Disconnect A/C lines from evaporator core. Plug A/C lines and evaporator core tubes. Remove instrument panel assembly brace to evaporator case bracket screw. Remove assembly brace.
  • Remove floor register and rear floor duct from bottom of heater/evaporator case. Remove nuts securing heater/evaporator case to firewall. Remove 2 screws securing support brackets to cowl top panel. Carefully pull heater/evaporator case away from firewall. Remove heater/evaporator case.
  • To install, reverse removal procedure. Evacuate and charge A/C system. Refill cooling system.
INSTRUMENT PANEL
Removal & Installation
  • Position front wheels in straight-ahead position. Disable air bag system. See AIR BAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT section. Disconnect negative battery cable. Remove steering column trim shrouds.
  • Disconnect all electrical connections from steering column switches. Remove cover from under steering column. Remove 4 bolts and reinforcement from under steering column. Disconnect parking brake release control motor from parking brake and ignition switch connector.
  • Disengage insulator retainer. Remove insulator. Remove 4 nuts and reinforcement below steering column. Remove 4 nuts securing steering column to instrument panel and lower column to front seat. Disconnect PRNDL cable (A/T models).
  • Ensure ignition switch is locked to prevent steering column from turning. Remove 4 instrument cluster retaining screws. Disconnect speed control cable and vehicle speed sensor (if equipped). Disconnect electrical connectors and remove instrument cluster. At steering column opening, remove one bolt securing instrument panel to brace. Remove one instrument panel brace bolt (below radio area).
  • Remove sound insulator under glove box by removing 2 push nuts securing insulator to studs on climate control case. Remove glove box door and compartment. Remove air cleaner housing, battery and battery tray. Disconnect wires of main wire loom in engine compartment. Disengage rubber grommet from firewall. Feed wiring into passenger compartment through hole in firewall.
  • Remove right and left kick panels. Disconnect wires from instrument panel at right and left kick panel sides. Remove screws on left and right sides of instrument panel.
  • Pull up to unsnap right and left speaker opening covers. Remove speaker covers. Working through steering column and glove box openings, reach under instrument panel and disconnect electrical connectors, vacuum hoses, A/C-heater control panel cables, and radio antenna cable.
  • Support instrument panel. Remove 3 screws attaching top of instrument panel to cowl top. Disconnect remaining wires. Remove instrument panel. To install instrument panel, reverse removal procedure.
Hope this helps...
Jan 17, 2011 | 1995 Ford Taurus
How do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
I need info on how to switch the case out
There is no written instructions. I looked online but there isn't any.
Follow this instructions
1)with the game-boy screen facing you, there are 5 round things there.
3 up and 2 down the screen.
2) put your screw driver inside there and remove it. Do it to all of them.
3) there are screw(nuts) inside those round things. so remove the screws(5) with the screw driver.
4)Don't open the LCD yet. Turn to the back of your gameboy, there you see 6 srews(nuts). 2 up one middle(for the battery) and 3 down. Remove the screws.
5) after you remove all 6 screws, the middle screw is for the battery. open the cover now the screw is gone and remove the battery.
(please remove any screw you see where the was before)
6) Open your game-boy with knife or with anything possible for you then the screen.
remove any screw on the board inside of the game-boy.
slowly and carefully disconnect a cable that is connected to the motherboard( LCD cable)
7) remove the speaker and then transfer it to the new skin, remove all the buttons and transfer then, now put the motherboard to the new skin, remove the Screen(LCD) then transfer it to the new skin. put the LCD cable you disconnect from the motherboard back. put the motherboard screw back. put the LCD screw back.
8) Turn to the back of the game-boy and put the battery back and all crews back. Now you are set enjoy!!!. feel free to ask me any question.
Jan 24, 2010 | Nintendo Game Boy Advance SP Console
How do I change the battery on the motherboard of Toshiba 4600?
BSOD's (Blue Screen of Death) on the 4600 series almost exclusively come from bad memory sockets (you have two), while the RTC issue (date/time) is un-related. Only in extreme rare cases have I seen both memory sockets go bad - so you can probably get around one bad socket by using only the "other" socket. The memory compartment is at the bottom, square big door covering it held in by 2 screws.
The RTC battery (CMOS battery) requires separation of the lower case, as it's located between the main battery and the palmrest. To get to it:
1. remove all bottom screws labelled B16 and B6 (including ones within the battery compartment);
2. remove the 2 screws in the back of the laptop;
3. remove the keyboard cover strip above the keyboard;
4. remove the 2 screws holding the keyboard, disconnect and remove keyboard;
5. remove the 3 (B16) long screws on the left half, and the 2 short screws behind the CD-ROM drive.
6. disconnect video cable, floppy cable, and mouse cables, and wireless antennas.
7. now you can separate the lower case from the upper case/screen assy. You'll see the RTC (cmos) battery - it should be dressed in green with two wires (red/blk) connecting it to the motherboard.
That's should be it. I'm citing all this by heart, so forgive me if I miss a screw here or there.... :-)
Oct 15, 2009 | Toshiba Satellite Pro 4600 Notebook
What needs to be removed from my Yamaha YPG-625 to
DO NOT open the case unless you are aware of and comfortable with the fact that you could _destroy_ your piano. Easily.
Observe appropriate anti-static precautions. It should go without saying that this is an electronic repair, and dangerous voltages may exist inside the case.
1. Remove the stand if you have one
2. Lay the keyboard upside down (bottom up) on workbench
3. Remove all 90+ screws from the bottom of the chassis, including the 14 inside the speaker compartments
4. Carefully lift up on the bottom case part, taking not to damage the speaker lines
5. Unplug speaker connector and set lower case aside
6. LCD is mounted beneath main logic board
9in the center), my problem lies elsewhere, but competent and cautious service technique should lead you where you need. I would strongly recommend replacing the LCD assembly module, unless you are experienced in LCD repair.
Jul 06, 2009 | Yamaha Full-Size Keyboard
Toshiba Satellite Pro 4600 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
