Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemeni double oven stovetop stopped working
Hello-
My oven stopped working. The stovetop does not work at all. The ovens I believe do. When I ran the Quick Test the error message
H3 132 comes up.
  • 2,427 Answers
Thats the controller, you'd need to call a professional no quick fix for that one sorry. besides attempting to fix it your self will cause more damage than good
Posted on Jan 02, 2008
Oven not working properly
Do you mean 200 degrees Celcius or Farenheit? If Farenheit then the most likely culprit would be the thermocouple in the oven which can usually be replaced relatively easily by someone mechanically minded, if Celsius then you should suspect the elements although a working broiler would suggest that there is at least one element that works fine. Maytag says; "Why won't the oven heat up? First, make sure you've properly set all the oven controls. Check your user's guide for more information on your model's controls.(see below for the link to the manual if you need it) If your range offers the option of a delayed oven start, check to see if it's been selected. If so, the oven won't begin to heat until the selected time. If your oven has a lockout feature, check to see if it's been selected. If so, it will prevent you from using the oven. If your oven still won't operate, please contact an authorized Maytag service provider for more assistance." Here is the link to the manual; http://www.maytag.com/assets/product/8113P564-60.PDF and here is the link to Maytag Service if you need it - hopefully not; http://www.maytag.com/support/service_parts.jsp The other possible culprit would be the electrical supply to the oven - it may be adequate for the stovetop or grill but the oven may draw more power than the circuit can handle - even if it was fine before, this can change and may be caused by corrosion, rodents, overloading etc. and may not necessarily trip the breaker switch - if you suspect this at all then get a qualified electrician to check - it shouldn't take long to check so should be cheap, although repairs if necessary may cost more Hope this helps :)
Jun 21, 2007 | Maytag MER5555Q Electric Kitchen Range
Maytag electric range model# MERH752CAS oven and stovetop stopped working.
Check the breakers. The range runs on 220v and one of the breakers may have tripped and it is running on 110v. Post back the results.
Feb 10, 2013 | Kitchen Ranges
F19 error code on lg double oven
had F19 error code on lower oven, F9 on upper. Pulled stove out and turned the regulator switch ON. Worked instantly. I thought I had the regulator on because the stovetop worked. The stovetop regulator is separate from the main regulator!!
Jun 22, 2011 | LG LWD3081ST Electric Double Oven
Stovetop works but oven does not.
Most likely your problem is the glowplug aka oven igniter. Even though it comes on it must reach a certain temp for the gas to come on. Occaisionally the valve will be bad but 90% of the time it is the igniter. Part number is 74007498
May 29, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Dec 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag double oven model # mer6770acw code f1-1 and f3-1 appears on the panel when using the ovens ofcourse when it gets warm or hot the ovens stop working.thanks for help
still i have the with oven heats up and stops working the codes coming on the panel are f 1-1 and f 1-3 range model # is maytag double oven mer6770acw
Sep 09, 2008 | Maytag Kitchen Ranges
Maytag gemeni oven
This sounds like a faulty igniter in the oven (about $45,00) online and you can replace it yourself. Look inside the oven and remove the bottom. You will see a long tube where the gas comes out. At one end of the tube is a coil of wire that is suppose to get white hot and yours is bad, probably only turning red when you turn on the oven. Good luck.
NSSMS
Jul 04, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
376 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
