the audio in Hitachi 62 in rear projection tv was intermittent and now it gone completely, I just replaced the Convergence chips because it had the 3D color separation ,i was able to fix that problem , now i need audio
Comments:
Oct 31, 2009
- Sorry for the bad info this is how it reads in the back of the unit Hitachi 61swx12b v11000525 sep. 2001
Oct 31, 2009
Nov 02, 2009
- yes, a
i was running external surround sound because the speakers were not working . the audio was repaired about 5years ago under warranty and now nothing .
Model number 55VG825 IS NOT 62 INCH SET, IT IS 55 INCH DLP.
WHAT IS ACTUAL MODEL NUMBER OF YOUR TV?
I can give more information if you give me correct model number---if convergence is now working, it has nothing to do with sound unless you created the problem when you repaired it.
The more info you give me the better I can help you.
I am here to help people, I do this here for free.
SD TECH
Comments:
Oct 31, 2009
- IT makes sense--a lot of these sets had a surround sound board---if it has it----from the back of the set it will be on the left side wall of the set--all kinds of problems---board is no longer available and the only way to get one is send the one in the set in for rebuild---PTS ELECTRONICS
Usually with this set sound will be intermittant--saw new ones with the board bad----I presume you have checked in the menu and the speakers are not turned off etc-----
This board feeds all the audio--external jacks and inside the set as well--about 180 for a rebuild--you had no audio problems at all before the repair?
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank You,
" - anvel
Popular Solutions for Hitachi UltraVision CineForm
When i turn on my Hitachi the picture is fuzzy, like 3d w/o the glasses, for about 2-10 minutes and...
(More)
When i turn on my Hitachi the picture is fuzzy, like 3d w/o the glasses, for about 2-10 minutes and then the pictures goes normal for the duration of watching. got the TV when it first came out, about 5 years ago. How do I fix this?
when i try and turn my tv on the power light blinks blue and the fan and lamp light blinks red the...
(More)
when i try and turn my tv on the power light blinks blue and the fan and lamp light blinks red the everything turns off after about 30sec can i fix this myself
