Hitachi 43UWX10B 43 in. Rear Projection Television
Problem for Hitachi 43UWX10B 43 in. Rear Projection Television
Manual Convergence adjustment on Hitachi 43UWX10B
By dgakovic on Oct 31, 2009
I have Hitachi 43UWX10B and the color is out of sync. I have replaced the convergence chips with the updated STK-392-150 version. I checked the resistors and they all seem OK, no burn marks and resistance is as it should be. The problem is that the picture is still distorted. I press the "Magic" button and picture is still the same as before. How do I manually adjust the convergence on this TV? Magic button goes thru the sequence but the picture is still like 3D. Please help.
Solution #1
posted on Nov 04, 2009
Not Rated)
free123radio
Rank: Apprentice
Rating: 0%, 0 votes
I'm not sure if this is the fix yet but took out convergsnce board and found one of the resistors to be burnt will replsce tomorrow and repost if good news
Was this helpful?
Yes
No
Solution #2
posted on Oct 31, 2009
Not Rated)
SD Tech
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 97%, 900 votes
I would guess you missed a open resistor--there are only about 12 of them--how did you check them?
This set (43uwx10b) has a tiny blue micro switch on the front of the chassis---if you engage it from the front the set will go into the DECAM or convergence mode--let me know the CLU number on your original remote and I will scan and paste instructions---98% of the time if the set is wacked out and will not adjust one of the resistors is gone---ONE OF THE CHIPS GETS THEM.
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Hitachi 43UWX10B 43 in. Rear
Questions and Unsolved Problems for Hitachi 43UWX10B 43 in. Rear
Do you recommend Hitachi 43UWX10B 43 in. Rear Projection Television?
Answer
Answer
when you turn tv on it takes 5 minutes or more to get a clear picture doublr image
Answer
power went out when tv turned back on double images 52 inch hitachi
Answer
green, pink color waves at top of screen and wording on screen is double
Answer
rear projection tv made pop noise then picture and sound went out. power light is on.
Answer
I have a Hitachi Ultravision HDTV model number SP-43w. When you turn it on it is red and wavy across... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 43UWX10B 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 752
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
