my bissell pro heat clear view is not spraying when I press the trigger. what is the problem? I have check the belt and clean the machine. Is there something else?
I believe the water pump is broken. You can order a new one for about $22 and try to install it (it is located under the plastic near the cleaning solution holder). It requires removing quite a few screws, but if its just the pump, its easier than replacing the valves/solenoids under the water tanks
just got a bissell proheat clearview force cleaner, we press the trigger, no water sucking action or...
(More)
just got a bissell proheat clearview force cleaner, we press the trigger, no water sucking action or shampoo release going on .. what's wrong?
won't **** up dirty water. and manual is NO help. Used for half the carpet, worked fine. Now I have...
(More)
won't **** up dirty water. and manual is NO help. Used for half the carpet, worked fine. Now I have dirty wet carpet!
have the lower unit apart and can't get the water selector to line up so that i can put it back...
(More)
have the lower unit apart and can't get the water selector to line up so that i can put it back together again.
