Need information hi i need schematic for yamaha ax 700u audio amplifier i think my power supply blow so i want to know what voltage suppose to come out the power supply thank you marc
    Problem Solver:
  • 10 Answers
Try http://www.servicemanuals.net/
They are not free, but the amplifier service manuals I have purchased through the site have been very good.
Posted on Jan 02, 2008
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha power amplifier p5000s powersupply does not switch on; even after replacing theshorted components eg.g4pc50u,what do i do now?
Hi
when you change the part on the power supply did you check that the voltage is the same as it should be.
maybe there is no voltage to the protection unit in this case the Amp will not power on
if you want to fix the Amp let me know
ecrdn@yahoo.com
Jack
Oct 13, 2010 | Yamaha P-5000 Amplifier
Yamaha AX-500 amplifier won't turn on!
Check fuses in back. If not fuses the power supply is dead. Buy a new one. They do weae OUT EVENTUALLy
Mar 09, 2010 | Audio Players & Recorders
Carver power amplifier Pm1.5, 110 acv accidentally plug in to 220
magnetic field supplies are different than conventional types, check that the thyristor is working properly
Feb 23, 2010 | Audio Players & Recorders
Yamaha AX-930 Audio Amplifier
HI...
Do a websearch for a competent repair shop in your region or ask the stereo folks where you got the amp.
It WILL need surgery.
Cheers,
Scott
Jan 01, 2009 | Audio Players & Recorders
Blowing fuzes
If the fuses blow before the remote voltage is applied, the power supply FETs or the reverse protection diode has likely failed.
Let me know if you have any other questions.
Aug 29, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Coustic 601se power on but bad sound
This is generally caused when there are blown output transistors but that generally causes the fuse to blow or causes the amp to go into protect mode.
If you connect a 15 amp fuse in series with the main power wire and it blows when remote voltage is applied, the amp is drawing excessive current. The problem could be either in the power supply or audio circuits.
Do NOT apply power without having the transistors clamped TIGHTLY to the heatsink. They can fail in seconds when there is a problem. The heatsink helps protect them.
The following page may be helpful when troubleshooting.
Amplifier Repair Primer
Aug 23, 2008 | Coustic Car Audio 601SE Car Audio...
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Dec 21, 2007 | Pyramid - PS21KX 20 Amp Power Supply Car...
99 people viewed this question
 Grubhead
Grubhead
