Question about HP iPAQ HX2490 Pocket PC
Activesync via bluetooth
I am using an ipaq hx2490b running windows mobile 5. i am trying to us activesync via bluetooth but there is not a connect via bluetooth option, only via IR. am i missing something? every solution for bluetooth connection says "select connect via bluetooth. what do you do when there is no option?
Click on Ipaq wireless
turn on the blutooth
Click on Manager
at the bottom click on new
and then click active sync via bluetooth and go from there
Posted on Feb 11, 2008
How do i use the internet connectivity of my computer to browse on my mobile when connected to my ipaq instead of gprs of the phone
Just connect it through ActiveSync (XP) or WMDC (Vista and 7), through either a USB cable or a bluetooth connection. Then, make a partneship between both devices. Your computer's internet connection should become available on your phone.
Hope it works for you.
Regards, Carlos
May 24, 2010 | HP iPAQ 914c Business Messenger - Windows...
HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
Mar 28, 2008 | Computers & Internet
Help with pre-owned iPAQ h5555
I have an IPAQ 5555 and although it's old it works pretty well. A few things to be aware of - you need to upgrade the ROM to the latest version. I don't have the links to the downloads but you should be able to find them on the HP site.
The problem that you will likely run into is Windows 7 and Activesync. I did everything via Activesync on Windwos XP - hooked up to my PC and installed software, sync'd appts and contacts etc... Activesync won't install on Windows 7 due to "incompatibilities"
I just installed "Windows Mobile Device Center" for Windows 7 and was able to get my device connected to my machine but syncing is not yet working.
As for WiFi access, from what I remember it's just a matter of turning on the networking via the Ipaq Wirelss app (icon is a little green square) and then turning on WLAN. That will hopefully cause two little left and right arrows to appear up in the top blue bar on the device's screen - the top left LED should also flash green to indicate that you're connected to your network. If the LED is flashing amber then your networking is on but your not connected to anything yet. If this is the case then the icon showing will likely be two arrows with an x. Touching this icon should open a small window called "Connectivity". On this window you can click on the "Settings" link, go to the "Advanced" Tab and rthen click on the "Networks" button at the bottom of the resulting screen.
You should now see a list of available networks - make sure your router is broadcasting Wireless G and not just N or you probably won't see it. If you do see your network's SSID then touch and hold the entry and select the "Conect" 'option on the resulting menu.
Starting out I would keep your wireless security turned off just to keep it simple. If you can connect this way then you can think about securinng your network. Once secured it's basically the same proceudre but you just have to enter your WEP key.
btw if installing some of the HP service packs etc.. for 5555 doesn't work using Windows 7 and the Mobile Device Center (it may .. I haven't tried) you may try loading Windows XP Mode on your Windows 7 box and then installing Activesync in the virtual environment and working in there just to get your device upgraded
Hope this helps. Good luck
Dan
Feb 19, 2010 | HP iPAQ H5555 Pocket PC
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
How i can sync my Ipaq h3955 with my pc win xp
In order to sync your iPAQ with Windows XP or earlier, you will need to download and install Windows Microsoft ActiveSync 4.5 from:http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx.
Notes:
You can use ActiveSync 4.5 only with phones that run Windows Mobile 2003 or later versions. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 phones. (To see which Windows Mobile operating system you’re using, if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync information to any of these phones, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
Download and install ActiveSync:
1. Click the download link on this page, and then click Continue.
2. Select whether you want to register for the Windows Mobile newsletter, and then click Continue.
3. Click Download files below, and then click Download (next to the Setup.msi file).
4. In the File Download dialog box, click Run.
5. Follow the instructions in the Installation Wizard to install ActiveSync.
Note: You must use a USB cable to connect your phone to your computer the first time you use ActiveSync to synchronize information.
Jan 10, 2010 | Compaq iPAQ H3955 Pocket PC
Activesync connection problems
this due to usb you just download hotfixes form microsoft updates and also download win xp service pack 3 which is available in windows site
Feb 15, 2008 | HP iPAQ rx1950 Pocket PC
Pocket pc 3850
Set it up with what? Do you mean sync with your computer? Are you using USB or Bluetooth?
Best thing to do.
1. Unplug your USB connection from PPC -> Computer
2. Uninstall Activesync if you have it installed
3. Restart your computer
4. Re-install activesync
5. Restart your PPC
6. When asked to connect the PPC connect it via USB
Jan 06, 2008 | Compaq iPAQ H3850 Pocket PC
Sync via bluetooth
Does your USB adapter provide serial port connections ? I had the same issue with an USB adapter with a dedicated-to-phone software. I changed to MSI bluetooth adapter and then made a serial port available to COM5, then connect activesync to COM5. (make sure on the ipaq you create a shortcut "activesync connection" and pair with the bluetooth adapter.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
I have bluetooth Activesync working on my hw6515 connected to a Dell x300. Followed the instructions in the User Guide Chapter 9. Need to take note of the com port assigned to bluetooth serial port on the PC. Connection must be initiated each time from the IPAQ ie go to buetooth manager and connect the activesync shortcut.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
Hw6515 series and GPS
When connected with Activesync you can use your Internet connection on the PC. In the Activesync Window: Options/Rules/Pass Through - Connection: The Internet Then leave the PDA in the cradle and access the Internet on the PDA, works automatically ever after.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
