I've tried to figure out how to change the light inside the microwave (not over the stove), by looking at the diagram on the sears.com webpage. The part I bought was WB08X10050, halogen lamp. Near as I can tell, I have to remove the top of the microwave to dig into the area where the lightbulb resides. If so, who designed this so that a lightbulb couldn't easily be changed? Called Westinghouse and was told there is no way to change the bulb. I was also told there is no recall or rebate available for it. I decided to take your suggestion and try to remove the over cover, but that requires a special tool as the screws have a little "stud" in the center and the opening is round on the top and half star shaped on the bottom. Evidentally, they don't mean for you to take the cover off!!
Some models use an tamper-resistant screw which can be removed with a specially-designed tool available from home improvement stores & appliance parts stores.
But some folks just use a hammer to tap and loosen the screw, then a "star", t-type, or small flathead screwdriver can be used to remove the screw.
Sometimes the screws are tough, so you may only be able to just bend the post slightly with a punch, then a small flat blade will "grab" enough to turn the screw. Pliers on the handle will help, too.
Another creative solution is to use a hacksaw or a Dremel tool to carefully cut a slot in the head so a flatblade will fit it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Was this solution helpful? Show your Appreciation by rating it:
