I have a 42'' Magnavox Plasma 42MF231D/17 that is about to turn 3 years old. Just the other day, when the TV was turned on, it shows a weird color ''pattern'' or ''snow'' and turns red after a couple of minutes. There is also no sound. The power cable was removed for over a day to try to ''reset'' the unit with no luck. All cables have been checked and even with no cables attached (other than power cable) the same problem continues. Any Ideas??
Comments:
Nov 09, 2009
- What other name might the part go by? i can't seem to find a "ssb" or small signal board.
Thanks
Nov 09, 2009
Thanks
Nov 10, 2009
- Thanks, I appreciate the help!
Nov 11, 2009
- I am also not finding the "main Board", or the "scaler board" either.
I will try to find the owners manual and see if it is listed in there.
Hi my name is Roety,
I can help you with your issue ,
Sounds like a bad SSB small signal board
login as a guest and check price and availability at
encompass.com
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Comments:
Nov 09, 2009
- Also called the scaler or main board.
not the x or y main
sorry can't find it listed online. will check a service manual on monday
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Philips Magnavox 42MF521D/37
My Magnovox Plasma Model 42MF230A/37 has no picture, no sound. POwer LED on front cycles from blue...
(More)
My Magnovox Plasma Model 42MF230A/37 has no picture, no sound. POwer LED on front cycles from blue to red. No flshing led, just an internal relay clicking. I have removed the rear, noticed the large center board has 4 1" Diam capacitors that are bulging. Also a blue square capacitor that is bulging out the sides. I am an electronics technician, but have never worked on TV's. Are the bulging capacitors the only problem or is it just a symptom of a bad power supply?
Phillips tv which is connected through our DVD player, and has sky tv attached. A visitor fiddled...
(More)
Phillips tv which is connected through our DVD player, and has sky tv attached. A visitor fiddled with one of our controls and now we only have a funny yellow-green-purple coloured picture.How can we put it back to original. Sound is fine
I have a fine gray vertical line down the center of my Philips Magnavox 47'' LCD TV. It's only 2...
(More)
I have a fine gray vertical line down the center of my Philips Magnavox 47'' LCD TV. It's only 2 years old.
