when changing the volumn either up or down the unit goes mute. to correct this i half to change from whatever setting it is on the another and then back to origainal setting. for instance:
set on cd/dvd to aux then back to cd/dv
please help
Pauline
Comments:
Nov 01, 2009
- the solution you gave was the answer i needed to solve the problem. thank you.
dis connect all the external wires connected to the unit.also remove the main power cord from power outlet for a minute then wait for two minutes and check out by connecting every thing as it was.also if still the same problem then it Can be the fault in remote as when you press the volume up or down button the mute option is getting applied /just check out with any other spare remote and confirm the fault.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
the dvd/cd tray is stuck in ours also (bose 321). cleaned the dvd, put it in the tray, and now the...
(More)
the dvd/cd tray is stuck in ours also (bose 321). cleaned the dvd, put it in the tray, and now the tray won't open.
Bose 321 DVD player is making a noise when watching a movie and then freezes this goes on and on...
(More)
Bose 321 DVD player is making a noise when watching a movie and then freezes this goes on and on when the player gets heated up. Is there something I can do it is roughly 3 years old.
i bought this a few years ago and now for some reason when i put a dvd in the picture comes out...
(More)
i bought this a few years ago and now for some reason when i put a dvd in the picture comes out blueish. and when i just use the speakers when watching tv, it shuts off by itself sometimes. why?
