Ribbon hook-up I have a new asus motherboard and I need to hook up my hard drive-cd-rom and cd-re-writer and have a ribbon with 5 pin hookups- I can not get the right hook up-I can get the cd-rom to work if I hook up on a 3 device ribbon- Can anyone gice me any advice on getting this right.
  • 62 Answers
You should be using two, two connector IDE ribbon cables if I understand your questions correctly.
On IDE 0 you connect the hard drive and one cd drive.
On IDE 1 you connect the second cd drive.
You will need to make sure the jumper settings on the drives are correctly set.
Posted on Jan 03, 2008
Should the hard drive and the cd rom use the same connection cable to a M2N68-AM PLUS motherboard?
It is recommended that you use a separate cable for hard drives, and CD-ROM drives, especially if your CD-ROM drive is a CD burner. This goes for any computer system. Placing a hard drive and CD-ROM drive on the same cable can introduce performance problems, especially when reading from a CD or writing to a CD.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 17, 2011 | ASUS M2N68AM Plus Motherboard
Dvd writer doesnot showing in bios
Theres' a couple things you need to double check. If you also have a CD-ROM drive connected to the same data cable as the DVD-ROM writer check the jumper on the back side of both. One should be pinned with a two pin jumper and set as a master and the second should be set as the slave. The back side of each ROM drive is marked M for Master, S for Slave & C for cable select. (Cable Select not suggested).
Double check the data cable. Remove and re-seat at the motherboard and at the ROM drives Parallel ATA data cable. Also check the power cable. Remove and re-seat. If everything is connected and the two pin jumper correctly and snug you should see the DVD listed in the BIOS.
Performed a restart and check your BIOS.
Cheers'
Mike
Jul 20, 2010 | ASUS K8S-MX Motherboard
How do I hook up the 2 audio outputs from CD-ROM on Intel D101GGC
You shouldn't need to connect audio connections from drives to the motherboard unless you are using A Win 9x operating system. Digital Audio Extraction is used for WinXP and later and the analog cables are no longer needed
Sorry no info on the pinouts
Mar 29, 2010 | Intel D101GGC Motherboard
LG CD-ROM not ejecting the tray
you need a pin..ir a small object...
do you see the small hole in the front of the cd rom??/you need to hit it so that it will open...
try it first...
hope i've help you.. rate me,..
Feb 06, 2010 | Computers & Internet
We are having problems running the program. The
I'm not sure what program you are talking about, but if you have just installed the DVD, make sure that the pins on the back of the drive are set to master if this is the only DVD/CD/ROM drive you are using. If you have another DVD/ROM device running from the motherboard and connected to the DVD from the same ribbon, you will need to make this a slave via the pins on the back of the DVD/ROM.
Nov 07, 2009 | Pioneer DVD 104 Internal DVD Drive
My motherboard doesnt have that long prong connector for the cd rom drive so how do i connect the cd rom drive?
What you will going to do is find a nearest computer store in your place and buy the connector for your cd rom drive.
Oct 25, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
I need a CD-ROM drive and cable for an Asus P2L-N/P2E-N board
Is this what you are looking for?
As for the conflict with the master drive, double check the jumper settings. Some drives have different settings for Master, Slave and Single drive. When given the option, try CS (Cable Select) and them them sort it out themselves.
It's also not usually recommended to connect an optical drive on the same cable as a hard drive. Sometimes you can't help it, but the optical is going to slow down the transfer rate of the HD.
Jul 01, 2009 | ASUS Intel 440LX Chipset P2L-N Motherboard
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
104 people viewed this question
Alun Cox
David Payne
David Payne
