Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover steamvac clean surge turbo power 5200 attachment problems
I do not have a manual and want to use the upholstery attachment. I can't figure out where all parts to the attachment goes and what makes it work. There is a thing that says install in tank, but I have no clue where that fits. And when turned on water comes out of the attachment but the brushes do not spin/work. Are there any suggestions, please help. Thank you
  • 1 more comment
  • Anonymous Mar 20, 2009
    no manual need directions to run steem vac.
  • Anonymous Mar 21, 2009
    cleaning tool will not go all the way down to connect to vacuum suction!
  • Anonymous Mar 25, 2009
    i think it's in right, but still no action on the hose itself
    President:
  • 1,673 Answers
That part to install in tank, is at the end of your hose. Take the lide off of the dirty water tank, on the front of the tank, there is a block that will slide out, then you can insert that part in its place. You have to have suction to make the brushes spin, so you just need to put the block on the end of the hose in the slot on the front of the tank. When down however, put that block you took out back, or your cleaner won't work right.
Posted on Jan 10, 2008
  • 25 Answers
Http://www.hoover.com/product.aspx?model=F5914900&ds=false if you go to this website they will have the manual for you good luck otherwise in the front of the dirt tank you will see a clear plastic piece it moves slide that out then slide your attachment hose in that spot facing up when you replace the lid of the dirt tank it will cover that and then therefore clean what needs cleaning after you turn it back on that is lol
Posted on Jun 21, 2009
My cleaning tool will not go all the way down to the connector of the vacuum. Do you have a solution for this problem?
Posted on Mar 18, 2009
  • jorge_a_l Sep 03, 2011
    The slot in the attachment faces up not down. I think you are trying to push it down to the slot coming from the floor. Turn it around. and it would fit the slot in the tank.
My spin brushes won't spin.
Posted on Jun 16, 2009
I can't find the manual for my turbo steamvac 5200
go www.fitness.manualsonline.com or www. retrevo.com or www.manualsfactory.com
finally you must go to Hoover.com and download
God bless you
May 16, 2012 | Hoover Vacuums
My hoover steamvac turbopower 5000ls will not spray for hand tool
my turbo 5200 will not pick up the moister into container to dry does anyone know what the problem may be
Sep 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
No suction for upholstery hose
http://www.hoover.com/pdfs/manuals/F5914900.pdf try priming your hose
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
Follow the instructions on pages 14 and
15 for the appropriate cleaning task.
Godbless
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Jan 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning uphoustry
I CANT FIRGUE OUT HOW TO PUT IT TOGETHER
Mar 05, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover turbo vac 5200
Pull out the brush block, do the brushes turn freely and is the shaft that goes uo into the turbine there or did it break off. If the brush block is ok, then the turbine is probably bad and will need to be replaced.
Dec 12, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Using upholstery attachment on the hoover spin scrup heated cleaner
I had the same problem. Instead of wasting time/energy I could use cleaning the furniture, I decide to look online for a manual instead. I hope this helps. It helped me!! http://hoover.com/pdfs/manuals/F5914900.pdf Good Luck !!
Sep 08, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
3,594 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
