We have a Whirlpool Gold Conquest side by side refrigerator with a built in ice and water dispenser in the door. The model # is GS65SHAXLL03, when pressing on the ice dispenser arm nothing happens, no crunching ice noise, nothing. The shaft that turns the in-door ice bucket is not turning whatsoever. When I release the dispenser arm, I hear a winding noise like a clock clicking. Any idea what the problem may be?
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool Gold GS6SHEXNQ 25.6
Thanks buffalonyman, I don't see the part number anywhere on the fridge, I'll check my files for the...
(More)
Thanks buffalonyman, I don't see the part number anywhere on the fridge, I'll check my files for the manual (hope it's in there somewhere
Our whirlpool conquest fridge get hot to the tocuh when we plug it in is this normal it gets hot on...
(More)
Our whirlpool conquest fridge get hot to the tocuh when we plug it in is this normal it gets hot on the left hand freezer side just around where the icemaker is
I have the same problem as the other guy, it is a frozen supply line, we keep defrosting it with a...
(More)
I have the same problem as the other guy, it is a frozen supply line, we keep defrosting it with a blow dryer as well, but it eventually doesn't work again. Did yuo ever find the answer??
I have a Whirlpool Gold Refrigerator with a Conquest In-Door-Ice Ice Maker with water and ice...
(More)
I have a Whirlpool Gold Refrigerator with a Conquest In-Door-Ice Ice Maker with water and ice side-by-side. The water dispenses from the fridge just fine, but the ice maker is not producing ice. Any help is greatly appreciated! Troy
I need to replace the lightbulbs on the refrigerator side of my whirlpool gold conquest...
(More)
I need to replace the lightbulbs on the refrigerator side of my whirlpool gold conquest refrigerator. I bought some replacement appliance bulbs and they don't work. One glows faintly and I hear a strange off and on noise that goes away if I take the new bulbs out.
