Question about Motorola Mobility RAZR V3
Keypad quit working
The only button that works consistently was the on/off button. The rest work once in a while and very unstable. Sometimes when the key works it works properly. Sometimes it would say "voice Record Memory Full". But I did not record anything as far as I know. Everything else works fine. I did not drop the phone or get it wet or anything. Please help! Thank you!!
  • 2 more comments
  • Anonymous Jan 02, 2008
    the only button that works is my on and off button.
  • Anonymous Jan 04, 2008
    same as described by tyrian
  • tyrian Jan 05, 2008
    I fixed my phone in an easier way. I suspect somehow some moisture got into the keypad area, which caused this problem. So I put my phone on top of the vent of the heater. First time, just lying on its back it worked but had the same problem the next day. Then I flipped it open, and put the keypad side down on the vent and in a couple of hours the phone works properly. I know it is not the best way to fix the phone but at least it is not difficult to do. I wish the best luck to all you guys who had the same problem. I know that it sucks!
    I tried to unscrew those screws as recommended but they are so tight and I don't have the proper screwdriver so I had to find another way.
  • Anonymous May 27, 2008
    KEYPAD QUIT WORKING EXCEPT FOR POWER ON/OFF KEY
    Problem Solver:
  • 10 Answers
I already try by my self this step and it works!
- open 4 screw in the corner of u're lcd (open the rubber first)
- open connector flex cable (2 items)
- clean it with some cleaner (alcohol) with brush
- assemble it!
Posted on Jan 05, 2008
I had the same problem and discovered the speaker phone was on. Duh!
Posted on May 02, 2009
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
R-408HS some buttons dont work
If the unit does this the keypad area may be bad---cheaper in most cases to buy a new unit.
Jun 17, 2012 | Sharp R-408HS Microwave Oven
I have sears opener #139.53989. Every once in a while I have a down problem. It goes down within an inch of the floor and reverses. Sometimes I can hold the wired remote button and it will go all the way...
If the main light flashes 10 times when the door reverses it is a sensor problem. Check them very closely. If they are just a little off one of them will be flickering but it is difficult to see. This can also cause the problem to be intermittent. Tweak them just a little.
It is normal for that light to blink randomly.
Jan 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keypad not working
i have a lf cookie kp 500 and it is all touch screen and none of the keys work i can receive calls but cannot make calls or use any of the features
Oct 13, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Keypad not working
you will need to take the case off the phone and check behind the buttons where the pads touch the circuit board these sometimes get greasy or dusty causing it to not create a conection between button and the circuit board clean the circuit board with dry dust free cloth look for signs of grease or water damage if this is clean or after cleaning put phone back together and try buttons if they still dont work you could try replacing the keys that you press as sometimes after alot of use these fail to connect with the board properly causing buttons not to work if you replace these and still dont work then it could be a warped board this happens if you have sat on phone or had it in pocket and let on something causing pressure on the case and this will warp the board their is no cure for this the only thing to do is buy new phone as a new board will cost as much as the phone hopefully this is not the case it might just need your keypad replacing try my first two sollutions first if this dont change anything then i would take it to repair shop and see if they think it is a warped board hope this is some help to you
Nov 01, 2007 | Nokia 7610
Buttons wont work and Phone shuts off randomly
I need more info, like is the phone water damaged, did you drop it at all?
Aug 06, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility RAZR V3 Logo
127 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
