Question about SanDisk Sansa e250 MP3 Player
It overheats and wont turn on even though battery is full
Well, it gets hot for about 40 minutes then it turns back to normal and will not turn on.
  • snowman1 Jan 03, 2008
    My Sansa also overheated and wouldn't turn on for about 50 minutes. When it finally did turn on, the battery was dead. It is now recharged and working. I have had my Sansa e250 for about a week, and it has the new firmware installed.
  • 758 Answers
You need to contact sandisk so they can RMA your device..there isnt anything wrong your firmware...it is the device itself..so call them to see if they can set up and RMA for you...
Posted on Jan 03, 2008
Truck will not start had low fuel pressure 40 psi changed fuel pump still wont start but still trys turning over after ignition is off
You should go back to school an learn how to spell an how to wright .
FULL PRESSURE.THE TECHNISION
fuel technician
FOUL PRESSURE - fuel pressure . So , what's the point to all this ? Is there a question in all of this ?
Oct 06, 2017 | GMC Sierra Cars & Trucks
Grand prix wont start after driving 30-40 miles
Could be ignition or fuel.
You would check for fuel pressure when it fails to start. The fuel pump or pump relay could be failing when hot.
Same thing with the coils and ignition module.
Jan 12, 2013 | 1996 Pontiac Grand Prix
Location of coolant drain plug on side of motor for a 1995 mitsubishi montero
Not exactly,need to bleed air from system look topside of engine area for a bleeder port may need a filler reservoir full of coolant when doing this keep it full turn on heater full hot fan on high watch temp gauge if it gets hotter than normal reading and no hot air from heater ducts turn engine off ASAP it can be a pain in the grommet to bleed cooling systems but if you don't engine damage is imminent got to get air out of system drain plug on block does not sound right maybe it's on the top of block I have pulled hoses and filled system thru those and even used garden hose to force air out squeeze hoses rock vehicle and make big messes but don't overheat the engine from complete cool engine you have about ten minutes to get r done then let it cool down try again
Apr 02, 2012 | Cars & Trucks
I installed a new battery into my HP G60 233NR. However sometimes when i power on my computer i get a black screen. Sumtimes after sitting for awhile it will boot. Other times I have to unplug the battery,...
I have a G62 that I've taken apart a couple times to fix issues. Right now the video card has an issue with turning on. I can get it to work by turning the brightness down before I shut it down; it will boot normally usually. If not, I can flip the screen open and closed a few times and it will finally get going. It's a backlight powerup problem that I haven't the patience to sort out. The battery has nothing to do with it, except it diddles the voltage a bit and might get the display working. I can't see the bootup screen, though; if I want to change anything, I have to connect an external monitor.
I usually blow the dust out of it with an air compressor every few months (I use it rarely). Otherwise the heat sink and fan cruds up with dirt and overheats.
I like the PC even though it's 6 years old. It runs all distros of Linux nicely. Mint, openSuSE, Ubuntu, Bodhi, Puppy, Manjaro.
Apr 06, 2017 | HQRP Computers & Internet
When I tried to turn on my tv it made an odd noise, turned off and would not turn back on, even though it worked just fine about 10 minutes before I tried to turn it on again. Now it won't turn back on,...
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 01, 2010 | Sylvania LD-155SL8 15 in. LCD Television
Turns off after 10 minutes of normal useage then comes back on 20 minutes later
it has a cutoff switch two stop it from over heating check it isent blocked up sumwhere in the fillters or the pipes
Oct 20, 2009 | Kirby G6 Bagged Upright Vacuum
My phone wont stay on even with full battery...
Hi, you have issue with your Battery... get it replaced.
Jul 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
My jenson mp3 model smp-2gbl wont stay on
i have a jensen model# smp 2 GBL it wont play it comes on for a second then turns off. I took out the music put in new music then it played for 5 minutes then turned off and does the same thing again. I put in alot of new batteries that dont work either can you help me
Jul 09, 2009 | Jensen SMP-115 MP3 Player
Sandisk sansa clip mp3 shuts of and wont turn back on...
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
-Tha Mp3 Doctor
Nov 06, 2008 | SanDisk Sansa Clip MP3 Player
Overheats wont turn on? is it dead for good?
Thats weird, they use flash memory so it shouldn't heat up...but you obviously have an internal electrical problem so I say bring it back or get it repaired.
Jan 02, 2008 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
