Question about LG DLE2532W Electric Dryer
MINE BLINKS HE
I can't dry 2 loads back to back i have to let it cool off first and if i do it blinks HE. Is that for the heating element and if so, where is that located?
I have the same issue and eventually it just stops heating altogether.
I have already had to replace the entire computer board and now after 6 months have the same issue again. This must be some type of sensor defect.
  • fishizl Jan 21, 2008
    Thank you very very much! I did not find a circuit to press. However, with this information I did follow the two wires that connect to a metal sensor inside the drum to another connector. I unplugged this connection and then reconnected which seems to have reset something as I now heat. It is rather strange that unplugging the drying and flipping the circuit breaker several times did not reset the machine.
    Thanks
I have the same problem on my DLG2532W, I would dry one set of clothes and then on my second load after it went through the time, the clothes are cold. After the first time I noticed it, had a repair man come out, luckily I purchased the extended warranty with Best Buy, but the repair man took about a week to come and see it since he was from out of town since no one here could repair LG's. He said it was just a circuit breaker that trips when it gets too hot, since that is how the machine is, which is good, but not good when it trips every time you do a load of laundry!!!! The repair man should be what to do, which was the greatest think ever!!! But because it is a pain to take out the screw everytime it trips, I now have my dryer constantly apart so it is easier to push in the circuit. On my machine, you need to unplug the machine, or else you will get a little shock if you don't touch the right spot. You have to pop open the top of the machine, unscrew the top 2 screws of the machine and unscrew the screws around the circle so the front part of the machine comes off so you see the parts. The circuit is located on the bottom right of my machine between 2 wires, if you press it, you hear a click and then try the machine to see if it works now.
Hope that helps, frustrated LG owner like everyone else!!!!
Posted on Jan 14, 2008
Clean light just blinks and will not run
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks wich means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller; or the problem could be that 1 of the 2 switches inside the door latch is not getting engaged fully. Most of the time, I find that the cause to this problem deals with the latch, or the switches in the latch. If something (like a soda) gets spilled into the latch, it can cause the plastic parts to stick and not slide to engage the 2 door switches. You might need to take the latch out (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove it (without pulling out the dishwasher), by using a small screwdriver to release the little catches on either side of the "tongue" or "tang". Bend the center part down slightly more to give it more force, and then re-insert it. Then run the diagnostic cycle (by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry), let it run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 17, 2014 | KitchenAid Kitchen Aid Superba Series...
Dryer won't dry is there a filter which could be blocked
It could be the heater element if the machine is operational but not heating, or check the function buttons mine has a cool button that doesnt dry it just airs out laundry.
Jul 28, 2014 | LG WD-12126RD Front Load Washer / Dryer
I have a kenmore ultra 665 1627. The green front panel light blinks. And we can not run a cycle. Thanks
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller; but the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Jul 27, 2014 | Kenmore Dishwashers
I have a 665.16039401 kenmore dishwasher and the clean light continues to blink. I can not run any cycles
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... You say it blinks 7 times, pauses, and repeats, right? Well, 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches. Usually, the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. If the problem re-occurs, then the cause may be a bad heating element or a bad controller.
Mar 24, 2012 | Kenmore 15129 Built-in Dishwasher
Kenmore dishwasher clean light blinks
The computer needs to be reset. you may need to check the tech sheet that should have come with the dishwasher ( usually behind the toe panel) for directions on reseting it. If you cannot find the reset directions, let me know, I will have to look it up. thank you.
Jul 07, 2010 | Kenmore Dishwashers
LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Aug 25, 2009 | LG DLE2512W Electric Dryer
Amana dryer wont dry
Replace that square white one and it should start working.
Jan 12, 2009 | Dryers
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Does not dry all the way
I too have a similar problem. Drying light blinks, doesn't shut off, little if any steam escapes when door is open during drying cycle. Wonder if this is Ariston's Dynamic Drying? My unit is new too.
Aug 20, 2008 | Ariston Technologies LL64WNA Built-in...
MINE BLINKS HE
you got a vent restriction look behind your drier with a flash light and see if vents too long or mashed go outside when drying clothes see how much air flows comming out best way to do vent is 4in pvc drain pipe from hood out side to floor then 90dgree elbow up through floor short peice of pipe then foil drier vent from back to pipe with clamps your air flows blocked backing heat up in drier
Nov 12, 2007 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
82 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
