Question about Sansui VRDVD4005 DVD Player/VCR
Can not read any disc
Getting error C104 "Incorrect Disc" on any disc including prerecorded discs, it was working fine for a while. Got some VHS movies transferred to disc but now will not read it. Please help!!
  • pinoymonet Jan 07, 2008
    Tried to clean lens with disc cleaner but it will not read disc cleaner either, please help.
  • pinoymonet Jan 30, 2008
    The DVD player spins for a while, then it gets a C104 "Incorrect Disk Error" on any disk.
    President:
  • 1,944 Answers
Does it immediately say incorrect disc or does it spin for a while before the error message?
Posted on Jan 30, 2008
  • Damen Wong
    Damen Wong Jan 30, 2008
    Do you hear the disc spinning?
  • Damen Wong
    I am sorry but it looks like the that your unit needs to be serviced (probably the lens has malfunctioned).
    Novelist:
  • 167 Answers
Get some estimates from local electronics repair shops....
if you decide it isn't worth it to fix it.... as a last resort.... hit the top of the player (above where the disc tray is) a few times with your hand and check to see if it fixes it, then try it again a few times. When i did that my XBOX 360 was able to read discs again. (of course you may damage it more... but if you are throwing it out anyway... it is worth a shot)
Since the VRDVD4005 can output a signal, you could always buy a used video card for your pc that can accept the input, then get a dvd burner and do it that way... however that is a lot more complicated than the 1-click ease of the VRDVD4005
Posted on Jan 07, 2008
    Scholar:
  • 48 Answers
You need to open this device up, this voids your warranty. If you have a warranty just use it. Otherwise, remove all outside screws from the large metal cover that covers the top and left and right sides, it is also connected at the back.
When the cover is removed. Remove anything covering the cd tray and lens from sight. Inspect the area. And operate the system while the cover is off. Dont touch anything, just inspect as it move, you migh notice something odd. Manually clean the lens with high grade rubbing alcohol. This should allow the lens to see properly. Be sure it is clear of any smudge, streaks, or debris. Test the unit. Usually it will read if something serious hasnt gone wrong. Otherwise replace the unit.
    Scholar:
  • 135 Answers
It doesn't need to read disc cleaner, so you can let it keep on running even while it isn't recognizing the disk. Did you try simply plugging it out for 30 minutes and then plugging it back in?
  • Yonatan Horan Jan 07, 2008
    By the way, the problem is most likely a hardware problem with the disk drive inside the DVD recorder, so if it's still under warranty you should send it in for repair. If not, you can open it up and see whether something got disconnected (and clean the laser eye yourself, be very careful, use a Q-tip and some rubbing alcohol). Somebody who had the same error as you found the motor detached from body.
  • Yonatan Horan Feb 02, 2008
    I'm not sure why I got a thanks for trying rating. The solution I gave you was the same as the ones you received after mine. That is, the problem is a hardware problem and that you need to open the unit and try to fix it (if you're knowledgeable enough) or bring it in for repair otherwise.
    President:
  • 317 Answers
Probably the only thing you can do is get a cd/dvd lens cleaning kit and try cleaning the lens.
If that doesn't work, your dvd player probably needs replaced.
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
I have a Sansui model VRDVD4005. When I put a DVD
I think you need to take it to the service center, because there's nothing that you can do all by your self.The problems starts from the optical lens/ laser pick up, replacing the lens could be necessary.
Mar 07, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Cannot format a dvd-rw disc or record to the disc.
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Dec 30, 2009 | Sansui VRDVD4000 DVD Player/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
MRV700VR
EXT1 is not an error - that message means that the dvd player is on input "EXT1" - so it is trying to display whatever is connected to EXT1 in the back of your DVD player, whether it is a cable/sat box, another vhs player, etc. The message may be getting displayed for a number of reasons - but, if you put in an incompatilbe/unfinalized disc type, and it is not able to play that disc, it may default to EXT1 b/c it is searching for some type of usable signal.
The MRV700VR is only compatible with certain discs types - and the disc types that you are trying to insert must also be finalized discs. I would reccomend only using the compatible disc types listed in your user's manual - some of them are getting harder-to-find. 16x discs are very iffy with this machine. 8x discs are best.
I have the full user's manual, so I can give you any more details that you request.
-Tha Mp3 Doctor
Mar 18, 2009 | Philips MRV700VR DVD Recorder/VCR
Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Dec 27, 2008 | Sansui VRDVD4005 DVD Player/VCR
Will not recognize dvd discs
Welcome to the sansui got ripped off club...c-104 is more common than rain in washington...no disc? thats what the unit finally displays when it has taken a thorough dump. Give your sansui to someone you don't like, and go buy a panasonic.
Dec 29, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui dvd player wont play and dvd's... shows up as incorrect disc c104 error
Try cleaning the optics with one of those DVD cleaners.
When that probably doesn't work, you can hand clean the optics if you can figure out how to get at them. (easy on some, hard on others) If that doesn't work, it is prbably not worth going any farther
Dec 21, 2007 | Optical Coating Model 108 VHS VCR
DVD recording or playing.
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
Feb 07, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
257 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
