Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Incomplete info code 634 how to fix
Our Fax is showing an error message saying "incomplete info code 634.
how do we fix this?
Jerry Ward
  • 25 Answers
That codes says:
"Redial count over with no response
or busy tone was not detected.
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Posted on Jan 25, 2008
Kyocera Mita incomplete code 634
That error code is actually a communication error caused by no response from the called station or a misdialed number. Make sure the number is correct and redial it.
May 01, 2012 | Kyocera KM-F650 Plain Paper Laser Fax
DX-800 beeps with Incomplete Info Code = 720
Error Code 720: Cannot connect to the Pop Server. (Incorrect Pop Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the network Administrator
Regarding the beeping noises. The DX-800 has multiple settings for beeps, rings and the dialing monitor. If it is the latter, press MONITOR button once, then press the DOWN arrow, until silenced. Some ringer/beep settings are under Fax Parameters, some are in a special SERVICE MODE.
let us know if you can isolate which one and we can help turn it off. At least now you know what the 720 code means.
Good Luck!
Nov 10, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
What is error code 634
Error Code 634 indicates a call that was placed did not go through:
"Redial was not successful due to no response from
the called station or wrong number dialled.
Note: If busy tone was not detected, the machine will
only redial once
Sep 03, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Comm error 634
Receiving fax never picked.
Aug 14, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Error code 634 on Panafax UF-770
The receiving fax machine is turned off or not functioning. Try calling your cell phone.
Do you have a DSL phone line?
Nov 21, 2008 | Office Equipment & Supplies
error code 634 means that you have reached your limit of redials
Jul 29, 2008 | Panasonic PANAFAX UF-6000 Fax
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Cannot fax outbound but can receive
Recipient has an incompatible fax machine or is always busy
Jun 04, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
2,233 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
