Remove the ice bin . Press the door switch in , and press the dispensor actuator pad . In the back , on the panel with the prongs , there is a square box cut-out , which houses a white square plastic piece . If this piece doesn't lift when set on cubes , then the solenoid is bad or a wire has come off of the solenoid . To access this solenoid , remove the 3 or 4 screws holding the panel on . Also try lifting this plastic piece with your finger , to see if it is frozen . Also a sign that the cube solenoid needs to be replaced .
We have had several problems with our MSD2756GES side-by-side frig (mostly related to the ice...
(More)
We have had several problems with our MSD2756GES side-by-side frig (mostly related to the ice maker). In the last couple of years we have replace the #61005626 Water Valve and the #61005988 Adaptive Defrost Encl and have had to clean/defrost the drain hole several times. Now the ice maker is dripping water on the wall and shelf below it.
the external water and ice cube dispenser still dispense after pulling away. is this a stuck switch...
(More)
the external water and ice cube dispenser still dispense after pulling away. is this a stuck switch and is it easy to repair
first the climate zone drawers started getting too cold and freezing everything,I turned the drawers...
(More)
first the climate zone drawers started getting too cold and freezing everything,I turned the drawers off but now the entire fridge is too cold, even my eggs are frozen. And turning the thermostat to warmer is not working. Everything is still freezing.
i have a myers model 7345MESF30 TNLC softner.i have set to deliver 600 gallons per recharge. my...
(More)
i have a myers model 7345MESF30 TNLC softner.i have set to deliver 600 gallons per recharge. my problem is that cycle 1 takes 15 min,2 takes 58 min. 3 takes 98 min.then 3 repeats again for 98min. then 4for 11 min. this has been like this since day one and the manual does not explain how to correct.i spok via phone to a Mike who was in sales several times he said he would talk to a teck and send me the instructions to correct the problem, but he never did.
