Brother Fax 4750e Super G Drum
Our fax machine is telling us to replace the drum soon. We order a new drum and it arrived today. Where does it go?
    New Friend:
  • 120 Answers
Open the front door. the drum is the unit the toner goes into. make sure you follow the instuctions that come with it. I think you have to press the clear button with the front door open to clear the drum warning code. Lawrence
Posted on Feb 14, 2008
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
The drum on my fax machine is not working properly. need user manual brother super g3 33.6
No. It should be working but maybe you still have the Replace Drum on the LCD ? in this case, reset the drum counter
Oct 14, 2014 | Brother PPF-5750E 33.6K bps Super G3 Fax...
New drum replaced,but machine still ask for new drum
Wow. It's obscure and in the manual on page 13-24. Remove and replace the drum leaving the front cover open. Press CLEAR and then 1 to answser the Replace Drum YES question.
Apr 09, 2010 | Brother IntelliFAX 4100 Laser Fax
Just replaced drum unit in our brother 4750e intellifax, now makes horrible squealing sound when printing. Ideas how to fix?
the drum is not set good please remove the drum and install it again something you do wrong.
Check do the drum is`set good.
Jul 15, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
I have a brother 4750e fax that is sending occassional barcode looking black areas on the right side of page. receives OK Has new drum and clean scanner glass
My first guess is a bad drum unit. Inside the assembly is a soft, plastic blade that scrapes off the toner that didn't make it onto the paper, so the next page will be clean. If dirt is stuck under the cleaning blade, it may skip, making marks like that on the drum, which get transferred to the page.
Do you still have your old DR-400 drum, or can you borrow one from another machine? Swapping drums is the ideal test, if you can avoid buying a new one. If your new drum is bad, the seller should exchange it.
Jun 23, 2009 | Brother IntelliFAX 2800 Laser Fax
Intellifax 4750e, prompted us to change the drum soon. We did change the drum but it is still telling us to change drum soon.
We went to Brother website and obtained a manual and we were forgetting to reset the counter. Once the counter was reset, the message went away.
Jan 13, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax Problem
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
Oct 28, 2008 | Brother IntelliFax-4100e Fax
Brother PPF-2800 Fax Drum "change drum soon"
this it brother web side go there and will tell you how to do http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007573&Sympt=Why+does+the+display+still+show+CHANGE+DRUM+SOON+after+I+replaced++thedrum%3f&Model=61&ProductGroup=2&Keyword=change%20drum%20soon&ProductID=PPF2800
Apr 11, 2008 | Office Equipment & Supplies
Brother Intellifax 4100 - drum needs replacing
The drum is what the toner goes into. DR-350 or a similar #. You can get at staples or office max.
Apr 09, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother intellifax 4750e
You need to open the front cover, then press the "Clear" button, and then press "1". This will reset the drum counter.
Mar 27, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
392 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
