Remove the brushes from the base of the unit by pulling down and unlatching at ends. Is there a drive pin present? The pin will be a 1/4 inch square pin, about two inches long. It engages to the drive mechanism.
Second: Is the Brush Control switch on the hood set to full speed, or shut off?
If both of these are OK, then the problem would appear to be the drive mechanism is not rotating, and would need removed and repaired/replaced. That is accessed by removal of the hood.
when I use it it leaks out of bottom. when it off an water in tank leaks out of bottom,when its off...
(More)
when I use it it leaks out of bottom. when it off an water in tank leaks out of bottom,when its off an I pull the triggar it flows big time out of bottom. tank doesnt leak when off sitting with water in it
(More)
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam...
(More)
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam using by hoover steam vac deluxe spin.
