Question about Kenmore 75944 Gas Dryer
Kenmore gas dryer
Dryer heats up but does not maintain throughout cycle i have cleaned lint outlets interior and exterior lint is not the problem any help would be great
  • Melom Jan 05, 2008
    burner lights fine on initial start-up, but will not relight in mid cycle. The igniter glows for 10-15 seconds but the burner will not light . If you open the door and restart the burner will light . Have replaced the two thermostats and the photo sensor for the ingition/ burner . Please help. This is a 80 series Kenmore dryer 2002
    Mel
  • joehall Jul 21, 2008
    I have the same problem. How do you fix it?
My washer is spinning properly I ran the dryer last night with an open back or no tubing for the exhaust on the lint outlet it ran for 15 minutes relighting the burner and about the fourth time it tried to relight it would not
Posted on Jan 03, 2008
  • 33 Answers
Lots of people point the finger at the dryer when they have a problem you could have bad thermal cutoffs on the back of the flame tube BUT is your washer spinning properly to remove the majorityof water from the clothes
My kenmore gas dryer end buzzer goes off and dryer shuts down before cycle is complete
Instructions Things You'll Need:
  • Kenmore gas dryer
  • Vacuum with hose attachment
  • Replacement fuse, if necessary
    Dryer Not Heating
  1. Remove lint from your dryer's lint screen. Remove the lint screen from your Kenmore dryer and vacuum the area behind the lint screen with your vacuum's hose attachment.
  2. Check to make sure that the dryer temperature is set appropriately, and has not inadvertently been turned to "Air Fluff."
  3. Ensure that the gas valve on the supply line to your Kenmore dryer is completely open.
  4. Check the room temperature in your laundry room to make sure that it is at least 45 degrees. Your Kenmore dryer will not operate properly at temperatures below 45 degrees.
  5. Make sure that the dryer outlet grill is not blocked by a fabric softening sheet.
  6. Dryer Not Running
  7. Check to see that the dryer cord is properly plugged in to the electrical outlet.
  8. Check your fuse box to make sure that the fuse is not blown, or check your circuit breaker to make sure that it has not tripped. Replace the fuse if necessary or throw the circuit breaker.
  9. Check the outlet itself to make sure that it functions properly by plugging in a portable device.
  10. please comment on these solution on how it works by rating or voting.
Dec 30, 2010 | Kenmore Dryers
There is no heat
Check the exhaust vent tubing throughout. If clogged up with lint the sensor will shut the heating completely off all the time till cleaned
May 08, 2010 | Kenmore 62602 Electric Dryer
I HAVE THIS PROBLEM WITH MY DRYER STOP HEATING AFTER A FEW MINUTE
Good day,
Without a make, model or style of heating (gas or electric) I'm at a handicap.
However, if it is a gas dryer, and will heat the first cycle but nothing after that until it cools down, then it usually is the gas valve.
A coil kit, consisting of 2 black coils is usually what goes wrong.
They develop an internal short, and must be replaced. They are mounted on top of the gas valve with a bracket.
Unplug the wires and remove the 2 bracket screws. Install in reverse order. It's a pretty easy repair.
Apr 16, 2010 | Dryers
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
I have an Kenmore 80 Series Gas Dryer, the heat is not staying on. I've changed the heating element and no change. It heats up for 2-3min then turns off for 3-4min then restarts for 20-40sec. then off...
How are ya?
The heating element is supposed to cycle on and off to maintain a set temperature. If it takes too long to come back on again, then the thermistat is malfunctioning.
Take a temperature probe and stick it in the drum and let it run for a few minutes and note the temperature. Should be consistantly near 90 - 130 degrees. Good luck :)
Jul 18, 2009 | Kenmore 800 7983 Dryer
Kenmore dryer starts, then stops. Heated motor smell
First CLEAN out the lint, not just in the mesh screen, but also by opening up the dryer to check for lint around the motor, and the manifold that connects from the drum to the outlet tube. Open up the manifold, carefully, remove lint, and REPLACE the heat sensor/temperature thermocouple that is on the outside, and has a protruding point into the manifold ($20 or less). If the drum spins when you start the cycle, it is NOT the motor! The burning smell is probably LINT that stuffed into the outlet pipe and manifold.
I have cleaned the outlet tube, manifold, and areas under/around the drum for my dryer, and my rental properties and "fixed" the problem. If it still turns off, then get the correct replacement sensors and replace them. DO NOT open the heating element. The wires inside are fragile.
Sep 08, 2017 | Dryers
Kenmore gas dryer 110.72512101
Check your igniter coil. It sounds like this part could be going bad. Another possibility is that the thermostat is defective. Some dryers have more than one thermostat.
Yet another possibility is that your thermal fuse is faulty.
I would check this webpage for more troubleshooting hints:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/Whirlpool-and-Kenmore-Thermal-fuse.html
Jan 02, 2008 | Dryers
try your pipes at the back,you may have a split
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Kenmore 110.72512101 gas dryer
Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
Kenmore 75944 Gas Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
