Question about Philips 42PFL5332D 42 in. LCD Television
HDMI-No signal input
37PFL7662D/05
we've been playing DVDs through a laptop via HDMI successfully until the laptop power was switched off accidently while connected to the tv, now however when we try to play any DVD we get the 'no signal input' from the tv-help!
  • g_suttler May 11, 2009
    all setting are correct, it just simply stopped working all of a sudden...same message 'no input signal' in both HDMI 1 and 2 slots.
    it is recognised on the computer, it just wont visibly show on the TV!
  • 476 Answers
Turning the power off shouldn't have caused the problem.
Make sure the TV is set to the correct HDMI (1 or 2) by pressing AV on the remote and moving up and down the list.
Check the laptop is set to output through the HDMI socket.
Right click on the desktop -----> properties ----> settings
Actual options depend on your graphics card.
Posted on Feb 18, 2008
We have purchased a Samsung 55" Smart TV. We have it set up and working with Foxtel connected via the supplied fittings. How do we connect the DVD player?
The usual way is to connect it via a HDMI cable, for which the TV should have 2 or 3 input ports. You then select this HDMI as input on the TV to see a DVD playing.
Get a "high speed" HDMI cable. Some will say there is no difference between any HDMI cables, but they did see fit to increase the bandwidth in these cables for Blu-Ray DVDs.
Dec 27, 2016 | Samsung Televison & Video
Lg 42lt75 used to work with a bp630 blue ray player but now shows "No Signal".
have you tried connecting ur laptop via hdmi to tv? if it works you should probably check tv settings for hdmi, if not then it is possible that the hdmi controller from tv to have some problems, i had a similar problem with a philips tv and took it to service ending up in a total replacement of motherboard and led display
Mar 09, 2014 | Televison & Video
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
How do I play DVD on the BlueRay player?
According to the Vizio website, your VBR231 CAN play DVDs the same way a lot of Blu-Ray players can. The site blurb suggests the VBR231 is backwards compatible - which means your player should be able to play DVDs as well as Blu-Ray. Generally, most Blu-ray players can play DVDs if they are backwards compatible with them.
I do know Blu-Ray discs will NOT work in most standalone DVD decks.
MODEL NUMBER: VBR231
*Model Features:
* Full HD 1080p Video Playback
* Integrated Dual Band Wi-Fi - 802.11n
* 7.1 Digital Audio Output
* Backwards Compatible (see below)
*Compatibility:
* Plays Blu-ray and DVDs, Audio CDs, MP3s and Jpegs
* Multi-Channel 7.1 Audio Output via HDMI
* Playback and Enjoy Media via back USB Input (JPEGs and MP3s)
*Outputs:
* HDMI 1.3
* Component Video (YCrCB)
* Composite Video
* Stereo Audio
* Coaxial Audio
* Optical Digital Audio
I hope that helps somewhat.
Feb 02, 2011 | Vizio VBR231 Blu-Ray Player
Hdmi input from does not receive signal. Have connected output from cable box directly to TV and signal is there. Unit does not pick up signal. HDMI output from component works fine, as I can play DVDs and...
I have the same issue. I've opened up several tickets with Samsung tech support. I'm concluding that it's the BluRay rcvr has bad hdmi input & output circuitry. I'm returning mine to Best Buy where I purchased it for a replacement. Before I leave the store, I'm going to make sure that the replacement unit's hdmi inputs & outputs work @ the store.
Dec 28, 2010 | Samsung HTTZ522T Theater System
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
I have a new sony laptop with windows 7 and sony XBR6. Trying to hook up the laptop to the tv via HDMI. The laptop can 'see' the tv and the inputs menu on the TV shows there is something connected to that...
Hello. Do not use HDMI for this purpose, instead go to Walmart and get a usb cord that plugs into your tv. Then use the remote control for your TV to push input and locate your computer, usually at the bottom of the list. Regards, Joe
Dec 22, 2009 | Computers & Internet
Can't get Blu-Ray DVDs to play through my Acer laptop to LCD TV
The specifications of this laptop states that it has a Dual layer DVD R/W drive. This drive can only play DVDs and CDs but not BluRay discs and it can burn single and dual layer DVDs and CDs.
Jun 20, 2009 | Acer Aspire 5610-4648 Notebook
Philips 42PFL5332D 42 in. LCD Television Logo
796 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
