Question about ATI TV Wonder 650 (DNH100715331) Video Capture
Viewing This is actually for a ATI TV Wonder HD 650 but this is the closest I could find on here. How do you get cable box (Dish network) converted so you can view those channels on your tv tuner card?
  • 205 Answers
When you watch TV with a Cable Box or a Dish Network Box you are using a tuner inside that box. The signal that comes out of that box only contains one channel, the one you're tuned to. So you can take the output of the Dish Box and send it into your ATI tuner card, but you cannot change the channel to anything other than what the DIsh Box is set to. I'm sorry, but that's just the way it is. I use a Hauppague tuner card that has what's called an "IR Blaster". By hooking this device up to my Cable Box and I can used my computer to change the channel on the Cable Box itself.
If you had cable, you could run the cable into the TV tuner and watch the analog channels. I have Time Warner in my area and they still broadcast about 50 channels in analog. I cannot use the tuner card to watch any of the digital channels. This probably does not help you, but I thought you might like to know.
I want you to know that I don't get paid to offer these suggestions. I know it's a strange hobby, but I like to help when I can. Even though I cannot solve your problem I hope I provided helpful information and you will give this solution a positive rating. I've noticed that many times this type of question goes unanswered because nobody wants to get a bad rating when a problem has no solution. Thanks and good luck.
Posted on Jan 02, 2008
6ya staff
SOURCE:
Old model slyvania Tv not hd or flat screen connected to dish network, has purple words on screen not Info or anything I would understand ..the volume also has went it have the original remote but haven't...
Hello -
I suggest you contact Dish Network directly. You may need to have a converter box replaced or a new converter box connected to your old TV (and pay for the installation.)
Best wishe.
Feb 27, 2018 | Televison & Video
I have a dish 625 receiver and i wanted to know if i could use an rca to hdmi cable to connect receiver to hd tv
ashlinlow,
You can definitely use an RCA to HDMI converter, though since our 625 receivers do not have HD capability it won't improve the picture at all. If you would like to look into upgrading to HD equipment, you can reach me directly at [email protected]!
Tommy Faust
DISH Social Media Representative
Dec 05, 2012 | DISH Network ViP 211 DTV Receiver
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities.
The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too.
Once set correctly, you should have a great picture once again. I hope this helps & good luck!
Sep 04, 2012 | Sony KDL-40XBR4 40 in. LCD HDTV
I am trying to set my toshiba ct-90159 to connect to a converter box, however, I need to change to channel 60 and i can't figure out how to do that. I have a dish satellite with 2 cable hookups and my tv...
You should be able to just connect the satellite box A/V output to the A/V inputs on the tv without the converter box. Most converter boxs are set up for the tv to be on channel 3/4. Just input the number 3/4 or whatever into the remote of the tv and press enter.
Sep 01, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
How to view TV in a Desktop PC via a USB TV Tuner?
Depending on which kind of tv tuner you are looking (analog basic cable) or HD tuner, the higher end tv tuners will usually handle both basic cable or connecting via satellite or some sort of set top box.
I would look for the ATI TV wonder HD, your going to want a tv tuner that can do hardware encoding on the actual tuner itself, older tuners will rely on your pc to process a lot of the data.
Mar 18, 2009 | Compaq Computers & Internet
HD TV not passing the tests offered on network tv
Which network? Cable? Satellite? Dish or Direct?
With any of these providers, you should get an ATSC or "digital" signal. If not, the problem would most likely be with the service provider since they are converting the signal for you. The only way that your set would be affected is if you have an "off air" (antenna) signal only. At this point you would need a converter box. If your service provider is providing you with a HD receiver, then you should have no problem recieving HD (as long as your paying for HD). However, keep in mind, digital is NOT HD. If there is an incompatability with your receiver, check with your service provider for a software or hardware upgrade. Also, check with your local TV serviceman to find out if there are any software upgrades (firmware) for your TV. Being three or so years old, it is possible.
One last thing to check is to see what type of signal you are passing from your providers box to your TV (which type of cable". At a minimum, you need a "component" connection to pass HD content. A "composite" signal is standard definition. Best you can get right now is an HDMI cable. Best "one cable" source for video and audio.
Good Luck.
Tim
Certified TV
Jan 23, 2009 | Sanyo DP32746 32 in. LCD Television
Connecting DVD to cable only TV and Modulator box and Dish Networ
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Jan 01, 2009 | GPX D1816 DVD Player
Dish Network HD Monitor HD 40-300
I have a Dish Network HD40-310 Monitor. When you turn power on the green power light comes on, then tv makes funny noise, then goes off again without producing any picture. Any ideas how to fix?
Aug 02, 2008 | RCA Televison & Video
TV Wonder 650 USB
i am not able to remove the ati remote wonder 1.4 software from the control panel method as described bsn
Jul 08, 2008 | ATI TV Wonder PRO Remote Control Edition...
ATI TV Wonder  650 (DNH100715331) Video Capture Logo
199 people viewed this question
Top ATI Televison & Video Experts
Marvin
Marvin
Are you an ATI Televison and Video Expert? Answer questions, earn points and help others
