I have a Cannon i560 printer. The printer will not print in the font size that I have chosen for my document...the print is way too small. Please help!!!!!
Check to make sure you're not adjusting it to fit the page. This can shrink the entire doc.. Look in the print dialog window when you select print from the file menu. There should be options to select or deselect before clicking to print. You may also check your page setup to make sure you are printing at 100%. Let me know if you solve this one...
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a...
(More)
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a very old printer ?
Thanks
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
HP4180 all-in-one gear slipping problem. We've had this machine for about 1 year and have run no...
(More)
HP4180 all-in-one gear slipping problem. We've had this machine for about 1 year and have run no more than 50 copies through it. Under the glass there is a mechanism that moves along a strip with gear teeth. On the underside of the moving mechanism there is an electric motor with a black worm gear on the shaft. The worm gear runs a larger, white gear that in turn moves the mechanism along the geared strip. My problem is that the larger white gear and the worm gear don't align perfectly and now the teeth on the larger white gear are worn concave on about 20% of the circumference of the gear. Where can I get a new gear? I spaced the larger gear up with a thin washer so the worm gear would ride on a small portion of non-worn teeth and it works now but its only a matter of time before it slips again. Can anyone tell me what this moving mechanism is called that goes from side to side under the glass. The worn gear is housed in the underside of this mechanism. Looks like avery poor design as there is no way to adjust or align the gears. Thanks.
my printer is a canon ink jet its about 2years old but i use it a lot for work at home printer say...
(More)
my printer is a canon ink jet its about 2years old but i use it a lot for work at home printer say it's jammed but i looked with a falsh ligth .i was haveing issue printing somer work last nigth butit worked
