I think you ran it with oil mixed in the fuel. Did you?
Determine if the warranty is active first. Most warranties are effective for 1 to 5 years. If yes return it to where it was purchased or find an authorized repair facility. A written diagnosis by a good independent saw shop ($10-20) might be a good idea at this point. It is difficult to argue repair charges with an authorized repair facility without some documentation in your favor. ·Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter. ·Is the saw equipped with a decompression valve? Yes continue, no proceed with 3. ·Leave the ignition off, set the valve and pull the starter. ·Pull gently to release the valve. Is there a difference in the effort required? If yes continue with 3, if no repair or replace the decompression valve. ·Was this saw perhaps operated without oil mixed with the fuel? ·Remove the spark plug wire and plug. ·Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears? ·Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges? ·Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered. ·The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Poulan Wild Thing 2375 18" Gas
i used my hard disk just once, i have copied some information on it for the installation i have...
(More)
i used my hard disk just once, i have copied some information on it for the installation i have followed the instructinons now i wanna use it again but my pc doesnt see the connection with lacie, that normally should work i have windows on my pc acer
