Question about Sanyo DS27510 27" TV
Image flat line
My tv has a couple years of use. now only have a line in the middle, no image above and under the line. need solution to fix either change the vertical or welding or wire disfonction?? maybe a schema diagram would also be needed.
  • yanners1976 Sep 23, 2008
    sanyo DS35510. I have only a vertical line acrosss the screen. I have owned this tv set for almost 6 years,and i am shocked that major appliances such as this,does not last but a few years anymore.They are definetely not built as they used to be.
    Please help me fix this set
  • 579 Answers
Vertical sweep failure.
It will be an I.C. with a part number that probably starts with an LA_ _ _ _ and be on a heat sink in the vicinity of the connector going up to the yoke. Try replacing that. But first, check all the electrolytic caps around it for testing dry (sorry - takes a special meter to do it in circuit) or just replace them. May have lost power to the I.C. as well. Look the I.C. up in the free NTE crossreference at nte.com get a diagram of its pinout to find what pins the power and outputs are on.
Hope ya fix it!
Posted on Jan 03, 2008
60inch lg plasma green line down the middle
Visit this site named 'Electro-help' These type of fault to plasma TVs are described in detail there. Almost all plasma TVs will have same structured circuits. You can find which board to your TV is faulty, by referring details from this site. Check this link, and select the site named above. Pull up older posts there.
Jul 30, 2012 | LG 60PS60 60 in. Plasma HDTV
What have a red image in the middle of our plasma tv what could it be and can we get rid of it
Hello nacoleray,
Does it look like a burned in image? If so and if you have a brand new samsung tv, it should a scroll bar that cleans out the screen. Go through the settings and this should fix it. If it is last years model or older you may not have this feature. Go to a channel that is snowy, scrambled picture and leave it on for couple of hours. This should some what make it better. If it is not a burned in image it could mean that you have dead pixels. Unfortunately this is not something you can just fix. I suggest contacting your manufacture. I hope this helps, if not give me a feedback. Good luck.
- Joe
Aug 31, 2011 | Samsung 50 in. Plasma TV
I have a Samsung LN46B530 LCD TV. There are 2 parellel lines on my screen, tv is 2 years old, first started with 1 thin line in the center of the screen, now that one has gotten thicker, and another one...
These lines came on to the tv LCD screen panel by itself?Yes,than the board that call the T-CON board it is dying to causes this problems,if these black lines problems causes by u or an object by hitting it to the tv LCD screen panel itself,it can't be repair,the tv LCD screen panel itself it is dead and leaking radiations.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 22, 2011 | Samsung LN46B530 LCD TV
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
The image on the TV has sort of condensed and disappeared. Now there is a bright line across the middle of the screen and a sliver of (about an inch) of image above that line. The rest of the screen is...
You have a vertical output IC that needs repaired. You may need to only resolder the vertical output IC. If then you do resolder, you will need to check and replace any capacitor in the immediate area of the vertical IC. A weak or bad capacitor will heat up the IC, and create rings on the pins under the IC. Also check the solder grounds on any resistor and diode that are immediately near this IC. This will bring your TV back to full view. Thanks for asking and show a few hands of support!
Oct 04, 2010 | Hitachi 36UX01S 36" TV
There is a black line straight down the middle of the picture. Is there an adjustment for that? The Tv is only a little over a year old.
sounds like you have a deffective segment in the screen. if it's still under waranty see if you can have the tv replaced with a refurbished model.
May 31, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Horizontal Line through middle of TV screen
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
Blue droopy line in middle of tv, everything yellowish above
Your convergence ICs Stk-392-110s Replace Both ICs.If 110s use 180s if 020s use 040s other wise Go by number on ICs .Mat electronics has parts 1-800-628-1118.Thats Cheap for 300.00 if you only have to replace ICs! Check all resistors around ics replace them if burt/read bad.RK42 3.3ohms RK46 1.8 RK50 2.7
RK54 1.5 RK58 3.9 RK62 2.2 ohms.
Jan 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Black line on middle of screen
Hopefully you still have under warrantee. If not, sorry. This line if memory serves me right is because the tv has 2 picture panels on each side of the TV (they join up together to make one picture). Toshiba did not realize that the panels will start slipping thus creating this fine line from the top of the screen to the bottom. They have revamped the newer models and placed glass to adhere the panels together. Even though my TV was under warrantee I got a new one and have had this one for 1/2 year and now the picture just blew (there is sound but no picture.)
Take your TV back if it is under warrantee.
Dec 11, 2008 | Hitachi SSH2442 Television
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Sanyo DS27510 27" TV Logo
70 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
