Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Problem for Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I have been trying to turn it on but the pulley is
By israel9236 on Oct 30, 2009
I have been trying to turn it on but the pulley is too hard
Clarification Request
Posted by dontbother10 on Oct 31, 2009
This has been answered! Follow the instructions and eventually you will find parts of your piston adhered to the cylinder wall. Reposting the same question or hoping for a different answer won't remove the adhered metal! It was run in a lean condition!!! It is toast!!!
Determine if the warranty is active first. Most warranties are effective for 1 to 5 years. If yes return it to where it was purchased or find an authorized repair facility. A written diagnosis by a good independent saw shop ($10-20) might be a good idea at this point. It is difficult to argue repair charges with an authorized repair facility without some documentation in your favor. · Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter. · Is the saw equipped with a decompression valve? Yes continue, no proceed with 3. · Leave the ignition off, set the valve and pull the starter. · Pull gently to release the valve. Is there a difference in the effort required? If yes continue with 3, if no repair or replace the decompression valve. · Was this saw perhaps operated without oil mixed with the fuel? · Remove the spark plug wire and plug. · Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears? · Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges? · Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears? Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered. · The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH Lou
Best Solution
posted on Oct 31, 2009
Very Helpful)
dontbother10
Rank: Guru  Tools - Building & Power  Expert
Rating: 98%, 867 votes
The chain brake isn't engaged until engine speed picks up. The nice smooth bore the piston moves up and down in isn't smooth any longer. That is where the additional friction is being created.
Lou
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
jcshaw2
Rank: Apprentice
Rating: 0%, 0 votes
sounds like maybe the kickback brake is engaged,take the chain and bar off and try to start it to rule out that possibillity.
Was this helpful?
Yes
No
Popular Solutions for Poulan Wild Thing 2375 18" Gas
Questions and Unsolved Problems for Poulan Wild Thing 2375 18" Gas
Do you recommend Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin?
Answer
Answer
no spark for a craftsman 2100 watt generator
Answer
how to change the spline that holds the sprocket and clutch assembly together on a poulan wildcat... (More)
Answer
I need a manual for the Makita G650R Generator please
Answer
My Makita Generator, Starts but wont run for long. It appears there is a part missing on outlet from... (More)
Answer
mac 3200 saw will nit start even wuth starting fluid but does have spark
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Chain Saw Experts
Top Garden & Power Tool Repairmen
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
