Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Will not spray water or cleaner
posted by ptbob on Jan 02, 2008
had to install a new pump and motor got the hose mixed up now it will not spray
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 17, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1324 votes
When you put the top back on, the smart mix vale should be on the clear water setting. Make sure that the piston is on the smart mix know under the top.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on will not spray water or cleaner:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901 there is no flow of Liquid ?  Could it...
When I checked in the door labeled belt---I saw that my...
The water won't come out. Everything else works well. Just...
1 side of my brush will not stay up. Could this be a...
After having to change a belt I decided to do a really...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
