Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Stripes on my Samsung Monitor
Hello all:
Recently I am noticing that my Samsung monitor has these horizontal "bars" across the screen when I am surfing on line. It happens when a web page is loaded, and the bars would align with the lines of text on the screen. Those bars are just a slight discoloration that run across the length of the screen.
When I close out the browser (Firefox) the desktop image does not seem to have the same problem. I tried using Explorer instead and those same bars would appear with the lines of text.
How can I fix it?
Cheers
  • golfgru Dec 23, 2008
    my samsung monitor shows bars that look like barcodes and they are permanent on the screen. Also, when I first turn on the computer and get the Windows log on, there are muliple tiny boxes in a horizontal pattern all over the screen
    Problem Solver:
  • 13 Answers
The contrast may be to high.
Adjust the brightness and contrast to make it go away but still readable.
if that does not help the FL (backlight) is going and the unit will need to be replaced.
Sorry.
Posted on Jan 02, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
How to repair my Samsung Plasma, it has horizontal black lines across the screen.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 12, 2015 | Samsung PN50C450 50 in. TV
Our three year ol Samsung TV has dark horizontal lines across the top of bottom of the screen. It is getting worse
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Apr 30, 2011 | Samsung HL-R6168W 61" HDTV
Wide horizontal bars ghosting across screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty its usually 3 years
Apr 12, 2010 | Acer AL1916W 19" LCD Monitor
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor goes black with a white horizontal line across the middle of the screen
Check to see that the monitor cable is correctly installed. Also, make sure you have the most up-to-date drivers installed for your graphics adaptor card(both ATI and Nvidia carry catch-all driver programs to keep you up to date.) Tighten the cable screws of course, to make sure the monitor cable isnt just wiggling in its seating.
Jun 05, 2007 | LG Studioworks 900B 19" CRT Monitor
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
290 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
