Is it completly dead or do you hear a click (internal to TV)? If completely dead - check main ac fuse. Otherwise here are some tips: A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition. The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model (forSony -bad solders on horizontal drive transformer/regulators short)– for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection). The only way to determine the real cause is : By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound orpicture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour. Be sure to vote/rate me if this helped Thanks!
Comments:
Oct 31, 2009
- Unplug set -Remove back cover- follow power cord to main board. Look for this a6.3A 250VAC fuse
you can buy a service manual @ servicemanuals.net -or google model # to see if you can find one for free.
There is a strong vertical line pin-cushion effect. Also, the aspect ratio does not adjust so many...
(More)
There is a strong vertical line pin-cushion effect. Also, the aspect ratio does not adjust so many shows are cut off at the ends.
i have bad reception, the antena internal plug converter to cable plug seems to be defective it...
(More)
i have bad reception, the antena internal plug converter to cable plug seems to be defective it likes a resistance quick connector, behind the Tv set cover
Just got a new TV and want to sell this model. It's in great working condition. How much do you...
(More)
Just got a new TV and want to sell this model. It's in great working condition. How much do you think it would sell for like at a Garage sale?
My Sony KE-42TS2U screen comes on and menu displays however there is no picture. The stand by led...
(More)
My Sony KE-42TS2U screen comes on and menu displays however there is no picture. The stand by led blinks continously about every second. I ran the auto set up so I know the tuner is reading the cable signal as it sets up. However I cannot get it from the tuner to the plasma screen, any suggestions?
