If the remaining picture looks bright as normal then it sounds like the Horiz deflection amp has a failed component. Most likely a blown transistor or burned emitter resistor or both. Not to expensive to have repaired.
I have a blue double image on my panasonic pt-47wx49e projector tv. I've tried to adjust the...
(More)
I have a blue double image on my panasonic pt-47wx49e projector tv. I've tried to adjust the convergence from the set up menu. But no matter how many times I try to adjust the green or the blue, only the red crosses will move.
hello - the tv power turns on but 5 seconds later the power shuts off and will not turn back on. If...
(More)
hello - the tv power turns on but 5 seconds later the power shuts off and will not turn back on. If you unplug the power, and hit the power button, the tv turns on, but shuts off after about 5 seconds.
