Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spin cycle My washer was going through the spin cycle and seemed to get off balance and stopped spinning. The wash machine will not spin or agitate now.
    Master:
  • 619 Answers
The balancer spring are detached from spinning drum out of alignment /outbalance / replace balncer spring available in apliance center.
Posted on Jan 10, 2008
2 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
I have a Maytag Bravos top loader washer and it seems to agitate during the washing phase but when it comes to the spin cycle the water drains but the clothes are still soaked at the end of the cycle, as...
This happens to me to. It is because it believes it has gone out of balance and has stopped and gone ahead and timed out making you think it has completed it's cycle. I do not have a solution to this other that I am thinking of chucking this washing machine out the door and buying an older machine.
Nov 20, 2012 | Washing Machines
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
My Maytag FAV6800 will not spin the clothes
Here is a Fix if your machine model is a FAV6800A or FAV9800A failing in Spin Cycle with dC/uC unbalance errors.
Fix the Clutch issue and save your 1$K machine. Here is my Clutch Fix post. You can redistribute the wash load in your FAV6800A or FAV9800A till the cows come one and you will continue error out in Spin Cycle of the wash cycle or a Spin Only Cycle. I explain in this post the fix and how to diagnose the issue to the Clutch Pulley One-Way Roller Clutch bearing.
If you just need Clutch maintenance you could be back in service today. You or someone you know can do this and I will help with any questions…………Rich
May 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
Will not spin or agitate
Get the model number. It may have an off balance switch that is stuck. Try moving agitator like its off balance and then turn on.
May 18, 2009 | Washing Machines
MAYTAG WASHER LA512 STOPS IN SPIN CYCLE, POSSIBLY OFF BALANCE?
having the same trouble.. works in wash cycle, agitates fine, but mine actually slips the belt in the spin cycle..
Jun 25, 2008 | Washing Machines
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
175 people viewed this question
Dan Webster
Dan Webster
Sal De
