Question about Baby Gear
Folding exersaucer I'm having problems folding down my evenflo exersaucer??
    Scholar:
  • 64 Answers
Typically you would depress the buttons on the outside of each pedestal and then slide it down to fold it. If this doesn't work check to see if there is a broken spring, button or a secondary safety latch/button. If you are still having trouble , message back with the model# or year and I can be more specific.
Posted on Jan 06, 2008
6ya staff
SOURCE:
How to convert evenflo exersaucer
Here's a step-by-step article for converting the Evenflo Exersaucer. It has photos and videos. How to Convert the Evenflo Exersaucer into Stage 3
Mar 01, 2015 | Evenflo Exersaucer Triple Fun Active...
How do I convert exersaucer to activity table
Here's an article explaining how to covert the Evenflo exersaucer into the stage 3 activity table. How to Convert the Evenflo Exersaucer into Stage 3
Sep 01, 2014 | Evenflo Exersaucer Triple Fun Active...
I need to fold the evenflo exersaucer to store it
Unfortunately, folding it to store is not a simple task. You'll have to remove the base which will allow you to fold the legs. Although the article I'm referring you to is for converting the exersaucer into a stage 3 activity table, it does give instructions on how to remove the base which will allow the legs to fold. How to Convert the Evenflo Exersaucer into Stage 3
Feb 05, 2014 | Evenflo Exersaucer Triple Fun Active...
I am needing an instruction manual for an Evenflo Exersaucer Triple Fun 25800496 08/06
hi
here is a page link to instruction download
near to bottom of the page
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231883&txSearchDOM=1/1/2010
Oct 26, 2010 | Evenflo Exersaucer Triple Fun Active...
I need to know how to fold the Evenflo smart steps exersaucer. Thanks
You can go to this link http://www.evenflo.com/category.aspx?id=19 or just call the customer support number at
US: 1-800-233-5921
Canada: 1-937-773-3971
Hours of Operation
Monday - Friday
8:00 a.m. – 5:00 p.m.
Eastern Standard Time
May 02, 2010 | Evenflo Exersaucer Smart Steps 6161812 1...
Need to know how to fold down evenflo excersaucer! I have an excersaucer and no manual. I want to fold it down so I can get it in the car.
I can understand your frustration. Try this website https://plweb.evenflo.com/replacement_parts.aspx You would have to find out the model of the exersaucer you are using. There is also a number on this site that you might be able to call for assistance or for them to send you another manual. Let me know if you have any luck.
Thank you
May 01, 2010 | Evenflo ExerSaucer SmartSteps Active...
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
How do you fold the Exersaucer Smart Steps?
Onthe bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place..... The thumb laches can be hard just so you know
To unfold, simply press on the holding latches, and pull up
Jan 03, 2009 | Evenflo ExerSaucer SmartSteps ABC Stroller
Evenflo 3 in 1 Exersaucer Triple Fun
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231711&txSearchDOM=1/1/2008
Look here it has the instructions.
May 23, 2008 | Evenflo Generations
Baby Gear Logo
407 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
