Question about Onkyo TX-SR605 Receiver
Distorted HD picture when using Onkyo 605 receiver
I ran into problems hooking up my receiver when I tried to run my Tivo HD receiver and HD DVD through the receiver using component cables. When I hook up the TV HD player directly to the tv I do not have any problems. When I run it through the receiver the picture gets distorted (lines running through it, etc.) I have an older 1080i mitsubishi television. I know the onky 605 downconverts the 1080i signal to 720p. Could this be causing the problem? Any help would be greatly appreciated.
Thank you.
  • garcam Jan 06, 2008
    I'm having a similar problem, with Motorola Comcast digital cable box.
    Picture is fine for a few minutes, then get occasional loss of synch,
    and lines through picture. I don't think it's 720p downconversion
    issue, because that occurs only with HDMI connection. Also, you wouldn't get any hd picture at all if that were the case. I'd be interested in getting feedback on same problem, I don't know the solution.
  • Theory2 Jan 26, 2008
    I also have the same problem with a motorola cable box from time warner and the SR605. Any help?
Use a hdmi switcher and the signal will be spilit up evenly between the two
Posted on Jan 29, 2008
Onkyo 605 loss of audio on HD channels only
on your directv box, go to menu, setup, setup again, then audio, then dolby digital on the right and turn it on. assuming you have an optical audio cable from your sat box to your onkyo.
Apr 26, 2009 | Onkyo TX-SR605 Receiver
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Onkyo sr 605
Check with and download the firmware update from the Onkyo web site.
Mar 16, 2008 | Onkyo TX-SR605 Receiver
Tivo HD will not record when Onkyo HT-SR800 is off
Do you want to run all your cables thru the receiver? There really is no benefit for you to do this since that receiver doesn't handle HDMI audio nor do any kind of component to HDMI conversion. Might as well connect your tivo box directly to the TV with HDMI. You'll have to switch inputs on your TV between the cable box, but its not a big deal.
Feb 20, 2008 | Onkyo HT-SR800 System
1st time using component video connections on my onkyo
Yes, switch to the video input that you are trying to configure (i.e. video 1-4). Press the menu button on the receiver or the remote and cycle to video settings. There should be a setting that says "video output" or "output" - set that to component. You may also have to configure the Input for that particular setting. For instance, if you have an HD tivo going into component 2 but you want it to be Video 1. Select Video 1, hit the menu button and scroll to video setup. Select video input setup and cycle it to component 2. Next, use the menu to cycle to video setup, select video output, switch to component. This should solve your problem. As a sidenote, you may also have to configure the audio in/out if you're using digital coax or optical. Let me know if this works.
Feb 02, 2008 | Onkyo TX-DS787 Receiver
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
Re: ONKYO with New LCD HI Def Television
Hi Lucylu
I don't have a solution to your problem -- but I do have the receiver and want to hook up my Plasma TV through the ONKYO TX-DS474 receiver. Its a great receiver but am not sure it will "do the job" being so old in the tooth.
Hope you found a solution!!
Gary
Nov 18, 2007 | Onkyo TX-DS474 Receiver
Hdmi audio problem from tivo hd
Your tv is new? if it is then it has a remote link, Panasonic call it Viera link, Sony call it Bravia link. Check your tv if it has that, if it does turn it off.
problem should be solved.
Nov 12, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
215 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
