Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
IntelliFAX 4750E - Printer Busy
Im working on a bro IF 4750e, the machine is unable to 1) Send Fax, 2) Recieve Fax, 3) Copy. The only "error" listed is "Printer is Busy". The machine has good dial tone and a work around machine plugged into same jack has no issues. Im wondering if this might be related to a possible bad formatter. I have not tried a cold reset, as i know none of brothers control panel features. When i arrived on site, they had gotten the machine to print a small batch of ealier recieved faxes, but it stopped after roughly 15 with the "Printer is Busy" error. Also when attempting to print reports, that too fails. Anyone ever see anything like that - will trade HP/Lex solutions for this one.
  • PFMMX Jan 03, 2008
    yeah after surfing the web for a bit i was able to find a solution; and yours was right on the money. The really odd thing about this, is the machine had 98% free memory. So now if this happens again i know the right area to look at. i owe you a 6 pack of tall boys my friend :)
  • 22 Answers
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
Posted on Jan 02, 2008
  • Wendy May 07, 2012
    is there any way to clear the memory ?
Turn off error correction mode for Brother 4750e
I found this video I have embedded below which claims to instruct you on how to achieve this.
Mar 13, 2015 | Brother Intellifax 4750e Laser Fax Machine
We have Brother 4750e that says "printing online" but nothing is coming out? Can send a fax but will not recieve a fax? Any ideas?
Un plug the unit and see if it will reset it self. Oh make sure the phone line is in the correct port.
Aug 11, 2010 | Brother IntelliFAX 4100 Laser Fax
I have a Brother IntelliFax 4750e Thats giving me a message saying ''paper jam, open cover and remove jam'' Well I tried eveything to see the jam but there is not a jam there I"brother Intellifax 4750e...
contact brothers support and they will walk you through fixing it or send you to one of their service centers where it can be fixed or give you a service center you can mail it to..
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 12, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Unable to enter faxes while the machine is either sending or rece
turn off
Real Time Transmission
When you are sending a fax, the machine will scan originals into memory before
sending. Then, as soon as the phone line is free, the machine will start dialing and
sending the fax. If memory becomes full, the machine will send the document in real
time (even if REAL TIME TX is set to OFF).
Sometimes you may want to send an important document immediately, without
waiting for memory transmission. You can set REAL TIME TX to ON.
1 Place the original face down in the ADF.
2 Press Menu, 2, 2, 6.
3 To change the default setting, and then
press or to select ON (or OFF) and
then press Set. Go to Step 5—OR—For
the next fax transmission only, press or to select NEXT FAX ONLY,
and then press Set.
4 For the next fax only, press or to select ON (or OFF), and then press Set.
5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
6 Enter fax number and then press Fax Start.
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Speed Dial Setup on Brother IntelliFax 4750e
pdf.textfiles.com/manuals/FAXMACHINES/Brother%20Fax%204750e-5750e%20User%20Guide.pdf
Apr 03, 2009 | Brother Office Equipment & Supplies
Can't find info - comfirmation
Its called "Transmission Verification Report"
Press Menu, 2, 4, 1
Select ON or On+Image
This will come with every fax you send.
If you want to customize, see owners manual under, "Printing Reports"
Oct 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
When we copy on our 4750e fax it comes out with black page
Can you see light from the scanner unit with you make a copy or try to send out faxes? The bulb for the scanner may be burnt. You might be able to find a replacement bulb, search google or contact Brother.
Jun 16, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother intellifax 4750e
You need to open the front cover, then press the "Clear" button, and then press "1". This will reset the drum counter.
Mar 27, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
909 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
