Chevrolet 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Problem for Chevrolet 1995-1997 Chevy 1500 Truck Ignition Starter...
Didn,t pass smog because it had to do with the
By mydogbuddy10 on Oct 30, 2009
Didn,t pass smog because it had to do with the emesion and I can,t get any picture diagrams in the inter-net can you help?
Best Solution
posted on Oct 30, 2009
Very Helpful)
matney68
Rank: Guru  Chevrolet Expert
Rating: 90%, 160 votes
(1) EVAP Purge Solenoid Ignition Positive Voltage (2) To Intake Manifold Port (3) Fuel Tank Pressure Sensor (4) Fuel Tank Pressure Sensor Ground Circuit (5) Fuel Tank Pressure Sensor Signal Circuit (6) Fuel Tank Pressure Sensor 5V Reference Circuit (7) Fuel Filler Neck (8) Rollover Valve (9) Fuel Tank (10) EVAP Vent Valve (11) EVAP Vent Valve Control Circuit (12) EVAP Vent Valve Ignition Positive Voltage (13) EVAP Canister (14) EVAP Purge Solenoid (15) EVAP Purge Solenoid Control Circuit The purpose of the evaporative emission (EVAP) control system is to prevent the fuel vapors from escaping into the atmosphere. The EVAP transfers the fuel vapor from the sealed fuel tank to an activated carbon, or charcoal, storage device, or EVAP canister. The EVAP canister stores the vapors until the engine is able to use the extra fuel vapor.
When the engine is able to use the extra fuel vapor, the intake air flow purges the fuel vapor from the carbon element, and then the normal combustion process consumes the fuel vapor.
The system is designed to detect the evaporative fuel system leaks as small as 0.040 of an inch between the fuel filler cap and the purge solenoid. The system can test the evaporative system integrity by applying a vacuum to the fuel tank in order to create a small vacuum. The vehicle control module (VCM) then used the fuel tank pressure sensor to determine system integrity.
Operation The control module monitors the ability of the system to maintain the vacuum. If the vacuum remains for a specified period of time, then there are no evaporative leaks, and a PASS report is made by the control module. If there is a leak, the system either will not achieve a vacuum, or a vacuum cannot be maintained. Usually a fault can only be detected after a cold start with a trip of sufficient length and driving conditions to run the needed tests. The enhanced evaporative system diagnostic conducts up to 8 specific sub-tests in order to detect the fault conditions. If the diagnostic fails a sub-test, the control module stores a diagnostic trouble code (DTC) in order to indicate the type of fault detected.
Comments:
Oct 30, 2009
- control module monitors the oxygen sensors during normal EVAP purging in order to determine if the EVAP canister is storing a sufficient amount of fuel vapors. If the test indicates that the EVAP canister is storing a sufficient amount of fuel vapors, the remaining diagnostic tests for the EVAP system will store a pass. If the Loaded Canister Test indicates to the control module that an insufficient amount of fuel vapors are being stored by the EVAP canister, the Weak Vacuum Tests will run.Weak Vacuum Tests
The Weak Vacuum Test is performed by the control module in order to determine if the EVAP control system is capable of achieving a sufficient vacuum in the system. During the normal purging of the EVAP control system, the control module will perform the following:
• Command the EVAP vent valve ON or closed • Monitor the fuel tank pressure sensor signal If the control module determines that sufficient vacuum is not achieved, the control module will perform the following steps:
• Store a DTC P0440 after the first failed test • Store the data in the Freeze Frame and Failure Records • Turn the malfunction indicator lamp (MIL) ON after a second consecutive failed test If the control module determines that sufficient vacuum is achieved, the control module will perform the following steps:
• While the EVAP vent valve is ON or closed, turn the EVAP purge solenoid OFF or closed, and run the Small EVAP Leak Test. • Run the Purge Solenoid Leak Test if the first Weak Vacuum Test passes. • Turn OFF the MIL, if the MIL is ON because of a previous failed Weak Vacuum Test. • Clear the data stored in the Freeze Frame for the DTC P0440. The Weak Vacuum Tests will not run unless the Loaded Canister Test has run and failed. Small EVAP Leak Test
The control module performs the Small EVAP Leak Test in order to detect a small leak in the following components of the EVAP system:
• The fuel tank • The fuel filler cap • The fuel filler neck • The EVAP canister • The EVAP vent valve • The EVAP vapor pipes and hoses The Small EVAP Leak Test does not test the EVAP purge solenoid for leaks.
In order to run the Small EVAP Leak Test the control module performs the following steps:
• Turn OFF the EVAP purge valve. • Following the passed Weak Vacuum Test and while the EVAP vent valve is still turned ON or closed, run the Small EVAP Leak Test . • Monitor the fuel tank pressure sensor signal. The control module monitors the vacuum trapped in the system. If the control module detects an excessive decrease in the vacuum that is trapped in the system, a DTC P0442 is set.Purge Valve Leak test
The control module monitors the fuel tank pressure sensor signal during a cold start in order to test the EVAP purge valve. With the purge valve OFF or closed, the VCM expects to detect no vacuum in the system. If the control module detects a vacuum while the Purge Valve Leak Test is being performed, a DTC P1441 is set.Evaporative (EVAP) System Canister
(1) Purge Line (2) Vapor From Fuel Tank (3) Air
The evaporative system canister, filled with activated carbon pellets, stores the fuel vapors from the fuel tank. The engine vacuum purges the vapor canister during normal driving.Fuel Tank Pressure Sensor
The fuel tank pressure (FTP) sensor is a 3 wire strain gauge sensor much like that of the manifold absolute pressure (MAP) sensor, however this sensor has a very different electrical characteristic due to its pressure differential design. The sensor measures the difference between the air pressure, or vacuum in the fuel tank and the outside air pressure.
The sensor mounts at the top of the fuel tank sending unit. A three wire electrical harness connects it to the control module. The control module supplies a 5 volt reference voltage and ground to the sensor. The sensor varies a voltage between 0.1-4.9 volts. When the air pressure in the fuel tank is equal to the outside air pressure, such as when the fuel fill cap is removed, the output voltage of the sensor will measure 1.3-1.7 volts.
When the air pressure in the tank is 4.5 inches Hg (1.25 kPa), the sensor output voltage should measure 0.3-0.7 volts.
The sensor voltage will be approximately 1.5 volts when the fuel tank pressure is equalized with ambient pressure. The sensor voltage increases to approximately 4.5 volts when a vacuum of 14 inches Hg (-3.75 kPa) is detected.
Evaporative Canister Purge Solenoid
When energized, the evaporative canister purge solenoid allows the fuel vapor to flow from the EVAP canister to the engine. The normally closed valve is pulse width modulated by the control module in order to precisely control the vapor flow. The valve opens during the Enhanced Evaporative Diagnostic Test in order to create a vacuum in the fuel tank and then closes in order to seal the system.
Evaporative System Service Port
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 03, 2009
Not Rated)
Mustgo
Rating: 88%, 195 votes
Are you one of those people who TOP OFF the tank when filling up?
When the EVAP recovery system soak with few ounce of gasoline......the trap vapor will take few days escape.
EVAP system is design to handle fuel vapor. Few ounce of gasoline can damage the fuel vapor recovery relay and decrease the service live of the recovery lines.
You can accelerate the process by locating the charcoal canister (near the nose of the car and same side as your gas filler door)
MOVE the car to outdoor.
Disconnect the EVAP line and let it air out by itself.
DO NOT introduce any heat source or fan to speed up the process.
Reconnect this EVAP hose and use a small amount of starting fluid at the intake manifold.
Please post more information by Clicking on the comment link.
I will follow up.
Was this helpful?
Yes
No
Popular Solutions for Chevrolet 1995-1997 Chevy 1500
Questions and Unsolved Problems for Chevrolet 1995-1997 Chevy 1500
Do you recommend Chevrolet 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch?
Answer
Answer
it is an automatic transmission. how many quarts of transmission fluid does it take?
Answer
I'm having an ignition switch problem. I want to bypass the switch for my heater fan temporarily... (More)
Answer
96 chevy truck 4.3 litre;truck was off for 2 days,cranks but won't start.Replaced fuel... (More)
Describe your Car Security Systems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Security... Experts
Top Audio & Video Equipment Repairmen
in , PA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
