Hi
Can someone tell me the difference between the 2 DVI connectors, one with 19 pins, the other with 25 pins. I just got a HDMI DVD player, but have a DVI television. When I hooked it up, using a HDMI to DVI cable, I get a pink picture. I noticed the DVI on the T.V. had 25 pins, so I bought that adapter. Should I return it for the one with only 19 pins? I know it must be the cable or T.V. because my cablebox has HDMI, and that hooked to the T.V. also shows a pink picture.
Thanks for any response
SOURCE: HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
SOURCE: DVI alert, Your HD tv does not support HDCP,
Antipiracy warning , cannot be disabled or bypassed, it's a part of your tv. Because of it you will not be able to use the DVI connector to view blu-ray movies. You will have to use the Component (YPbPr) ones , at a much lower image quality.
Testimonial: "cool"
so where are ALL the experts?
